do a ton of 10's or 8's
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
that is very doable but you have to have the correct design and subs. Subs must have enough motorforce to move in 4cubes of airspace after all the displacement of the port bracing subs and wood.
DCAUDIO
BALLS DEEP
hold on do you have 10 cubes before or after port/sub/bracing displacement ??
R.I.P!
(Nov-29-2009)
92 explorer
current build
Well This is going to be the first build I do by myself so having the correct designs might be hard haha. But i like the input im seeing so far, thank you guys for helping :)
No, the only thing i put in the box design was the Port so far. I am still researching everything i need to know and this isnt going to happen untill i figure out what the hell I'm doing. But i used the box design calculator that is on this website (torrez i think?) and according to my measurements of my hatchback I have about 10 Cubic feet to work with.
that doesnt answer my question
do you have 10 cubes gross or net
look at torres calc
R.I.P!
(Nov-29-2009)
92 explorer
current build
so just throwing this out there with my 1 18 apxx its in a
8.7^3 cube gross box which leaves me with roughly 6^3 cube net after port and bracing and sub so if i was you i'd stick to 15s
R.I.P!
(Nov-29-2009)
92 explorer
current build
