:popcorn: GET TO IT
2001 GMC Jimmy SLE 4X4 Floor Shift AutoHeadunit - Alpine CDA-117Front Door Speakers - Alpine SPS-600C MidsRear Door Speakers - NoneDash Speakers - Alpine SPS-600C TweetersSub Amp - Rockford Fosgate T4002Mids+Highs Amp - Rockford Fosgate P4004Subwoofer - P3D215 Fosgate Punch 15Sub Box - Rockford Fosgate designed "powerful" ported box Built by myself
i would rather run cheaper but sexier then expensive and fucking ugly.
Okay, here is the deal. I no longer know if this build is going to happen. If I get this new job, my truck is getting traded in on something else a little smaller but much NICER. So, I may have to hold off on this....but if not, here is what I have once again.
MDF-Tomorrow morning!
Still waiting on my check...hoping that it clears soon so I can at least get my subs and amp...I have a friend who is going to hook me up with some 1/0 wire so I can do my big 3 and also, after doing a bit of research, I found an OEM higher output alternator that "should" suffice til I can throw $500 bucks at one. AD244 alternators out of stock chevy trucks will direct swap in place of my factory little guy. So with that said, for 80 bucks I am basically doubling the alternator power. Along with the new optima battery, it should hold up for a little while. At least long enough for me to power it and tune it, I do not plan on bumping it hard until I get another battery in the back and get the rest of the stuff I need. I also plan on using a soundstream BX-15 to clean up the bass a little bit. I have been traveling all weekend and it has been raining, so my truck still looks like bucttcheecks but, monday, when I start building my box I should be able to get some pictures up. If I need to redesign the box for my new car if and when that happens, then so be it...I just want to bump already. I hate this waiting game!
BassinBlazer
JL[RF][Kenwood][AQ]
I need a new amp! Sell me your amp!
Can a mod or someone please close or lock this thread? My blazer is not getting worked on any time soon. I just got a 92 jetta for a work vehicle and the blazer needs a ton of stuff done to it. Here is a list of things that have failed within the last 30 days or just need changed or replaced.
Brakes, front and back, again
Shocks in the front
Front CV or half shaft
4x4 has no high range, just low
coolant system is taking a shit
plugs wires coil, basically whole ignition system needs upgraded
Suspension basically is shot, front and need factory rear lead springs
Body is starting to rust
There is more, I just don't want to think about it. It is getting parked for the summer and returned to OEM condition, or better than it is now...because I need it for the winter and stuff like that. My wife plans to drive it this fall or winter, so it needs to be in good running and working order before I even think about putting a stereo back in it.
I just got a 92 jetta GLI that has some potential, and I may be working on that sooner rather than later. Probably put a small system in it, just to hold me over...
Anyway, mods, do your thing.
BassinBlazer
JL[RF][Kenwood][AQ]
SO it isn't as extreme as I wanted it to be, but it has bass. I am waiting on my AQ amp, either from the classifieds, or straight from AQ. I have a cheap amp hooked up right now and it is in a sealed box....A Rockford T1 12D2....Hits good and loud, even wired to 4 ohms, once I get my new amp, it will be 1ohm and hopefully I will be getting it in a ported box before long. I will post pics when it isn't storming outside...
BassinBlazer
JL[RF][Kenwood][AQ]
