1. Product:
Rockford Fosgate Power 400.4
2. Specs:
CEA-2006 Compliant
Number of Channels
4
Rated Power (RMS Continuous Power)
60 Watts x 4 @ 4-Ohms
100 Watts x 4 @ 2-Ohms
200 Watts x 2 @ 4-Ohms Bridged
2-Ohms x 2 Bridged Stable
Total Power (Sum of Rated Power)
400 Watts
Bridgeable Yes
Efficiency (average)
69% @ 4-Ohm
68% @ 2-Ohm
Crossover Controls
Front High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Front Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Rear High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Rear Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Tone Controls
Front Channels - Punch EQ
Treble: 0dB to +12dB @ 12kHz
Bass: 0dB to +18dB @ 45Hz
Rear Channels - Punch EQ
Signal Input
Front Low level: 1 RCA pair
Rear Low level: 1 RCA pair
Power Input Connector
Block
Power Wire Gauge
4 AWG
Speaker Output Connector
Screw terminal barrier strip
Speaker Wire Gauge
8 AWG to 18 AWG
Heat Sink Type
Cast aluminum
Cooling
Convection
Remote Controls
Optional Remote Punch EQ (overrides rear channel built-in Punch EQ)
Visual Indicators
Power
Thermal
Protect
Circuit Topology Class
Class A/B
Frequency Response
20Hz to 20kHz +/- 1dB
Shipping Weight
11.90 Lbs. (5.39 Kg.)
Dimensions (HxWxL)
2.14 x 8.14 x 13.66 (in)
5.42 x 20.68 x 34.69 (cm)
3. Description/Condition:
In great condition just minor cosmetic flaws.
Recently purchased from DeCaf
4. Price: :
$210 Shipped
5. Pictures:
Edited by thehoe92
Wouldnt be thehoe92 without teh purple
This topic is now closed to further replies.
