Amp Selection for two RE SE 10s
KzA
Getting a new car over the next week and I am starting to plan out a system for the car. Currently have two RE audio SE 10's without an amp. These will be going in a ported box, however it wont be too large since this is my DD and I need the trunk space. I have been thinking running 500-750 to these things.
Originally I was looking at a JL slash 500/1, however I just think its way too expensive and have a feeling you guys will be able to steer me in the direction of something just as good for much less $$. Thanks for any suggestions!
i dont know what kind of coils your subs are.
audioque and mb quart are good for the money. check those out.
Eclipse cd7000
The subs are 600w RMS dual 4 ohm voice coil... originally I had them hooked up to an old 1200 w audiobahn amp at 1 ohm.
They sounded great at low volume and got very loud, but quickly lost clarity as volume was increased. I want these subs to be loud but also clear and snappy as possible. My original thinking was to provide them a bit less power to obtain this goal, but would maybe running at a higher impedance help?
Sorry I'm not so knowledgeable on the specfics of choosing an amp haha.
Ok so after doing a bit of reading around Ive found that apparently running at 2ohm or 4ohm will help SQ versus running down at 1ohm.. Correct me if I am wrong..
Right now I am looking at the Hifonics Brutus BRZ1700.1D which will run 600W @ 4ohm. Any thoughts?
It isn't the running at 1ohm having clarity issues but rather the subs being used, you might want to redo the system as a whole new if you plan on going more towards an SQ system. For the sub portion it really isn't necessary to go higher than 1 ohm to be clean and clear but more in the stage portion where clarity is really noticed. If you read some recent threads about comps and such you'll find some good links and thoughts on what to buy and where and around what kind of price, if you take your time you can build a really nice sound system with not a whole lot spent.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
  • Who's Online   0 Members, 0 Anonymous, 569 Guests (See full list)
