Opinions/help on head unit noise
A noob question about head unit popping when I change tracks or from input points.I checked all grounds connections also the component speakers connections.With car running I have zero digital audio noise with volume half way.The head unit is Sony 550UI really don't have a clue how to get rid of it.It also dose it when volume is turned from whatever the volume settings are to zero or from zero to one or two.The amp dose not make any difference to the sound there is no turn on thumps so lost.Thanks.
The H/U itself may have a broken ground or a bad board inside causing the issues like your describing. Do you have access to another H/U to try and see if that in fact is the case.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
  • Who's Online   0 Members, 0 Anonymous, 904 Guests (See full list)
