SPLVan Posted April 27, 2011 Author Report Posted April 27, 2011 Do what u can with the money you have, but instead of buying mediocre equipment, save ur money, learn from everyone on the site and get a good setup once u have the coin. Like the initiative ur taking though, gotta start somewhere Yesssir, i think the cheapest thing in these new setup is gonna be those boss 5x7's and in my opinion i dont think i would be able to hear/care about a difference in sound between $30 and like some alpine's that are much more.. 1999 Dodge Caravan [TrashMobile] 8ga Power/Ground AudioPipe APSM-1300 (subs) Scosche 550 (mids/highs) Boss 735UA Headunit (2)Hifonics HFi12D4 Still Under Major Construction.. My Build
SPLVan Posted May 2, 2011 Author Report Posted May 2, 2011 Getting MDF tomorrow. will post pictures once i get the boxes built! 1999 Dodge Caravan [TrashMobile] 8ga Power/Ground AudioPipe APSM-1300 (subs) Scosche 550 (mids/highs) Boss 735UA Headunit (2)Hifonics HFi12D4 Still Under Major Construction.. My Build
SPLVan Posted May 8, 2011 Author Report Posted May 8, 2011 will be a 4.7 cubic foot box soon! 1999 Dodge Caravan [TrashMobile] 8ga Power/Ground AudioPipe APSM-1300 (subs) Scosche 550 (mids/highs) Boss 735UA Headunit (2)Hifonics HFi12D4 Still Under Major Construction.. My Build
SPLVan Posted May 12, 2011 Author Report Posted May 12, 2011 volt meter! 1999 Dodge Caravan [TrashMobile] 8ga Power/Ground AudioPipe APSM-1300 (subs) Scosche 550 (mids/highs) Boss 735UA Headunit (2)Hifonics HFi12D4 Still Under Major Construction.. My Build
SPLVan Posted May 22, 2011 Author Report Posted May 22, 2011 All i need is a distribution block and some more ground wire and we should be bumpin with a budget! box is being built; 4.7cubes with 10.3 square inches of port per cube tuned to just under 35hz 1999 Dodge Caravan [TrashMobile] 8ga Power/Ground AudioPipe APSM-1300 (subs) Scosche 550 (mids/highs) Boss 735UA Headunit (2)Hifonics HFi12D4 Still Under Major Construction.. My Build
SPLVan Posted May 29, 2011 Author Report Posted May 29, 2011 box is finally built! cleaned up my wires to my amps! just about done with the system. building a console next it will house (2) 5x7's a few switches and my volt meter! 1999 Dodge Caravan [TrashMobile] 8ga Power/Ground AudioPipe APSM-1300 (subs) Scosche 550 (mids/highs) Boss 735UA Headunit (2)Hifonics HFi12D4 Still Under Major Construction.. My Build
uhoh_45 Posted May 29, 2011 Report Posted May 29, 2011 everything's looking good but i have a suggestion for your power wire going to your amp- shorten the length between the fuse to the amp you can get rid of a foot or so of wire there R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
SPLVan Posted May 29, 2011 Author Report Posted May 29, 2011 everything's looking good but i have a suggestion for your power wire going to your amp- shorten the length between the fuse to the amp you can get rid of a foot or so of wire there all this wire was from a different setup in the back of the van. so now thats its moved up font ive got extra wire. but i think ill keep it that way in case i want to go back. thanks though! 1999 Dodge Caravan [TrashMobile] 8ga Power/Ground AudioPipe APSM-1300 (subs) Scosche 550 (mids/highs) Boss 735UA Headunit (2)Hifonics HFi12D4 Still Under Major Construction.. My Build
SPLVan Posted May 31, 2011 Author Report Posted May 31, 2011 1999 Dodge Caravan [TrashMobile] 8ga Power/Ground AudioPipe APSM-1300 (subs) Scosche 550 (mids/highs) Boss 735UA Headunit (2)Hifonics HFi12D4 Still Under Major Construction.. My Build
