RAM_Designs Posted April 26, 2011 Report Share Posted April 26, 2011 (edited) If you're going to use a slot port, you're looking at around 24" of height, minimum. Edited April 26, 2011 by RAM_Designs Quote Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011... Link to comment Share on other sites More sharing options...
dwright27 Posted April 26, 2011 Report Share Posted April 26, 2011 3 cubes total, big port area, Quote 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer Link to comment Share on other sites More sharing options...
RAM_Designs Posted April 26, 2011 Report Share Posted April 26, 2011 Or you could save some space by using a single 6" aeroport...but you only have 28" of width to work with, so that won't work. Quote Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011... Link to comment Share on other sites More sharing options...
onyx1silverado Posted May 11, 2011 Author Report Share Posted May 11, 2011 (edited) So if I go 3 ft total, do I need to make the box a little bigger to compensate for the the port or is it 3 ft and leave it at that. Also can I still do a down firing box? And will going ported sound better in a hatch like my cube than a sealed box. Edited May 11, 2011 by onyx1silverado Quote Pioneer AVH-P4200DVD Rockford Fosgate T5001 bd-cp 2 DC level 2 12's Focal Access Components in the front Focal Access Coax in the rear doors Rockford Fosgate Punch Boosted Rail 4 channel rms 4x75 XS Power D3400 under the hood Knuconceptz Ultra Fleks Power & Ground Link to comment Share on other sites More sharing options...
matt402 Posted May 11, 2011 Report Share Posted May 11, 2011 (edited) 3 cubes NET, which is after port, sub, & bracing displacement. id do a slot port with 45-50sq" of port. what are ur max dimensions to work with? Edited May 11, 2011 by matt402 Quote Link to comment Share on other sites More sharing options...
onyx1silverado Posted May 12, 2011 Author Report Share Posted May 12, 2011 thats a pretty tiny car, id fire subs & port up. read up & design box here >>> http://www.the12volt.com/caraudio/boxcalcs.asp 3 cubes NET, which is after port, sub, & bracing displacement. id do a slot port with 45-50sq" of port. what are ur max dimensions to work with? The max dimensions would be 37 wide 13 deep and open to height and that is with subs and port up. And i guess if I were to fire and port back it would be 37 wide 10 deep ? tall Quote Pioneer AVH-P4200DVD Rockford Fosgate T5001 bd-cp 2 DC level 2 12's Focal Access Components in the front Focal Access Coax in the rear doors Rockford Fosgate Punch Boosted Rail 4 channel rms 4x75 XS Power D3400 under the hood Knuconceptz Ultra Fleks Power & Ground Link to comment Share on other sites More sharing options...
matt402 Posted May 12, 2011 Report Share Posted May 12, 2011 id do 37"W x 13"D x 18"H. box comes out to 3.1 cubes net after displacements. port should be 11.5"H x 4"W x 25.25"L tuning comes out to 36hz. Quote Link to comment Share on other sites More sharing options...
Mx833 Posted May 12, 2011 Report Share Posted May 12, 2011 i'd say fire subs up, port back.. ive had better luck with the subs up in my past vehicles with no trunk. Quote Link to comment Share on other sites More sharing options...
onyx1silverado Posted June 25, 2011 Author Report Share Posted June 25, 2011 I noticed that most of the slot ports seem to be about 4 inches wide or more. Is there anything wrong with going with a 1 or 2 inch slot port so that it doesn't have to be as long? Quote Pioneer AVH-P4200DVD Rockford Fosgate T5001 bd-cp 2 DC level 2 12's Focal Access Components in the front Focal Access Coax in the rear doors Rockford Fosgate Punch Boosted Rail 4 channel rms 4x75 XS Power D3400 under the hood Knuconceptz Ultra Fleks Power & Ground Link to comment Share on other sites More sharing options...
Louisiana Bass Posted June 25, 2011 Report Share Posted June 25, 2011 You lose alot of port area. Quote N8. No homo...unless you want there to be. Link to comment Share on other sites More sharing options...
