Relyks Posted April 27, 2011 Report Posted April 27, 2011 ok when i am trying to get 2.00 cu.ft after displacement on torres calculator i am trying to get the gross volume right? not the net volume? does anyone usually put some type of glue or cocking/mold to make sure there aero ports are sealed? anything anyone would recommend that i can pick up from home depot or lowes to make sure inside my box is nice and sealed? Best screws to use? best glue to use? should i be ok if i let lowes/homedepot make my cuts? and the carpet do yall put on with adhesive , hot glue , or just glue? and last question would a slot port be better then a aero? i have my own opinion on all just seeing what u guys think. --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
18abVFL Posted April 27, 2011 Report Posted April 27, 2011 ok when i am trying to get 2.00 cu.ft after displacement on torres calculator i am trying to get the gross volume right? not the net volume? does anyone usually put some type of glue or cocking/mold to make sure there aero ports are sealed? anything anyone would recommend that i can pick up from home depot or lowes to make sure inside my box is nice and sealed? Best screws to use? best glue to use? should i be ok if i let lowes/homedepot make my cuts? and the carpet do yall put on with adhesive , hot glue , or just glue? and last question would a slot port be better then a aero? i have my own opinion on all just seeing what u guys think. net volume is after displacements. use wood glue, then seal the edges with silicone. Then if desired, lay down a coat or two of fiberglass resin for extra strength (and some say it may gain you a dB). use MDF screws from home depot, they are skinny, sharp and keep wood from splitting. do NOT let the depot cut your wood. I let some stoner there cut my wood, and he fucked everything up. I dont carpet my boxes, i prefer spatter paint. Leaves a "rock-like" finish. And i always prefer a slot port than an aero. 1999 Monte Carlo Sony CDX-GT34w 2 Alpine Type R 12"s in 4 cubes tuned to 35hz American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms) Stock alt, Stock batt, Big 3 Upgrade Boston s55- 5 1/4s (doors) Boston s95- 6x9s (rear deck)
illiniboy17 Posted April 27, 2011 Report Posted April 27, 2011 ok when i am trying to get 2.00 cu.ft after displacement on torres calculator i am trying to get the gross volume right? not the net volume? does anyone usually put some type of glue or cocking/mold to make sure there aero ports are sealed? anything anyone would recommend that i can pick up from home depot or lowes to make sure inside my box is nice and sealed? Best screws to use? best glue to use? should i be ok if i let lowes/homedepot make my cuts? and the carpet do yall put on with adhesive , hot glue , or just glue? and last question would a slot port be better then a aero? i have my own opinion on all just seeing what u guys think. net volume is after displacements. use wood glue, then seal the edges with silicone. Then if desired, lay down a coat or two of fiberglass resin for extra strength (and some say it may gain you a dB). use MDF screws from home depot, they are skinny, sharp and keep wood from splitting. do NOT let the depot cut your wood. I let some stoner there cut my wood, and he fucked everything up. I dont carpet my boxes, i prefer spatter paint. Leaves a "rock-like" finish. And i always prefer a slot port than an aero. pretty much sums it up right there^ Car: 1995 Thunderbird System: Pioneer deh5100ub HU Pioneer/Lightning Audio 5x7's 1 Hifonics 1610D amp 2 Obsidian Audio 12's 4cu.ft. box tuned to 30hz 8 farad Boss Audio cap 4 gauge power/ground wire Youtube Facebook
