You should def have two fuses between the batteries like you do in the diagram. And also like mentioned above I wouldn't mix two different types of batteries together. But if you do you should use a battery isolator so that one battery doesn't drain the other one.
? Dude run those batteries you will be fine.
Bang em if you got em
When you mix two different batteries together the weaker one is naturally going to try and take power away from the stronger one to increase it's voltage. Ultimately you will have a dead battery, so just use a battery isolator if you insist on using different batteries
