CruelSoul Posted April 28, 2011 Report Posted April 28, 2011 Can I make this work or will the subs be too underpowered,I will have the right speced box req big 3 kinetik hc600 for now 1/0 gauge tsunami wiring in a maxima
Supercharged DCs Posted April 28, 2011 Report Posted April 28, 2011 Are the subs Dual2ohms or Dual4ohms? What are your box specs? Is the HC600 under the hood or in the back? Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
CruelSoul Posted April 28, 2011 Author Report Posted April 28, 2011 Dual 4ohm box is prefab for now until i get specs to build a better one http://www.amazon.com/gp/product/B0013MT60E thats it there I was told its like 1.93 cuft per side and the battery is in the rear I have another battery up front or should i go and buy a brz2400 hifonics amp or a kicker 1500.1,and also what ohms should I run this with?Also my HU is 4v
Supercharged DCs Posted April 28, 2011 Report Posted April 28, 2011 If they are both dual 4, your only options are 4ohm or 1ohm. What battery is under the hood, stock? If so, you need to upgrade if you plan to run a Brz2400 to the pair. Prefab box is a no no mate, you would have been much better off saving your money to buy wood and do it yourself. Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
iceman1575 Posted April 28, 2011 Report Posted April 28, 2011 If they are both dual 4, your only options are 8ohm or 2ohm. What battery is under the hood, stock? If so, you need to upgrade if you plan to run a Brz2400 to it, though personally I would get the Kicker Zx1500.1, as it's made to run at 2ohms. Prefab box is a no no mate, you would have been much better off saving your money to buy wood and do it yourself. Try again. Dual 4 ohm = 1ohm, 4ohm, or 16 ohm. CVX 12's are 750w RMS, so you'll be underpowering them by just a tiny bit, but you should be okay. Try and get the 1500 if you're going with Sundown. Aim for about 1500-2000w at 1 ohm, if they are both dual 4 ohm (4 ohm per coil) subwoofers. POTATO!
Supercharged DCs Posted April 28, 2011 Report Posted April 28, 2011 Derp, I'm retarded Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
iceman1575 Posted April 28, 2011 Report Posted April 28, 2011 Derp, I'm retarded No politics, please, just thought it was funny. POTATO!
