OKK
alot of people have asked this question...
Whats better a small load or large load.? lol
well thats kinda what im asking but...
ok so if i take a load of 1ohm off a 10" sub, hook it up too an amp that's stable at 1ohm and puts out 1k watts at that impedance.
now heres the twist. Im not asking what would be better on "THAT" AMP.
Cuz i "KNOW" ill just get less power out the amp at 4 ohm DUE TOO THE LOAD.
Now... If i go an grab another amp that does 1krms at 4ohmms.
Now on overview of this is
x1 sub "1ohm" on 1k rms
x1 sub "4ohm" on 1k rms
The 4ohm load will require alot more volts. and cost more money, cuz its harder too do 1k at 4ohms.
has anyone ATUCALLY TESTED this and prooven it?!?!
isnt my sub gunna be seeing more power overall?!?!? its deffinitly seeing more voltage.
how can this not affect ANYHTING.just dont make sense too me. WHY?!?!?!
Ride Stats:
2003 Ford focus Zx3 Hatch Walled System
X1 Solo X Kicker 18" "Enclosure: 7.8 cbft, Port Firing Into a Horn, On a 90*"
X1 Rockford Fosgate 40001bd "Now a Warhorse On my dresser"
x1 0g Big 3
x1 Kinetik 2400 "x4 Kinetik 2400's"
x1 Kinetik 1800
x2 Kinetik Special Edition True Silver Battery Terminals
x20 Gold Plated 0gauge 3/8 Ring Terminals
x25 Total ft: KnuKonceptz Kable 1/0 Silver Pearl* 2500+ Strands.
x15ft KnuKonceptz 8 Gauge.
-Soon Too Be Walled
Fav Quote:
They Dont Feal Me, But They Feal Me.
most people ask...
whats better 4ohms on MY amp or 1 ohms on MY amp.
IM ASKING...
whats better
1sub at 1ohm to an amp stable at 1ohm for 1krms
or
1sub at 4ohms on a more powerful amp that will do 1krms at 4ohms, witch is harder too do...but dont i get anything out of it?!?!
Ride Stats:
x1 0g Big 3
x1 Kinetik 1800
-Soon Too Be Walled
Fav Quote:
Plus an amp at 4 ohms will be a lot more efficient than any amp will be at 1 ohm
so teqnically im drawing less current throught my power wire due to the higher voltage?
Ride Stats:
x1 0g Big 3
x1 Kinetik 1800
-Soon Too Be Walled
Fav Quote:
wouldnt i get more decibles due too the larger load making the cone move more with less amps?
Ride Stats:
x1 0g Big 3
x1 Kinetik 1800
-Soon Too Be Walled
Fav Quote:
Ding ding ding. 1K rms at 4 ohms is gonna have less current draw and require a less robust electrical system than 1K rms at 1 ohm. This is purely due to how the amplifier works. 4ohms is much more efficient than 1 ohm. Many amps you'll see numbers like
500 rms @ 4 ohms
800 rms @ 2 ohms
1000 rms @ 1 ohm
Lower impedances require more power due to lesser efficiency. That stated, it's still usually cheaper to get an amp to do 1K @ 1 or 2 ohms than to get one that does 1K at 4 ohms. The difference in electrical system requirements isn't big enough to make a cost difference. That really only comes into play if you're running below 1 ohm for competitions or feel the need to run .5 ohms daily.
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
500 rms @ 4 ohms
800 rms @ 2 ohms
1000 rms @ 1 ohm
FINALLY I GET IT!!!
so that all means amps like the jblgti6000 that does alittle over 8k rms at 4ohms, simply does the same thing watts wise, just draws alot less power thru my wire too supply the amp.
so the difference is...
hifonics sampson at 1ohm does 8k but draws current a different way.
the jbl is going too be better cuz its gunna draw less amps, to do the same power cuz the voltage makes up the difference?
thus the difference isnt seen on the meter, but on the alternator? lol YAY
correct?
Edited by solosickness
Ride Stats:
x1 0g Big 3
x1 Kinetik 1800
-Soon Too Be Walled
Fav Quote:
SO WAIT A MINUTE...
SO THE QUESTION IM REALLY TRYING TO ASK IS...
HOW THE FUCK DOES THE JBLGTI6000 DO more power with higher ohms?
or it it just a very magical amp that other compainies should look into cuz that is BEAST. lol
im not a fan of buying more alternators...
just increase voltage, i find it stupid too run 6-7 runs of 0gauge wire when i can just run two lines, and do the same thing.
I think other companies should realllly look into this.
the jblgti6000 is a step into future amplifers in my opinion.
Ride Stats:
x1 0g Big 3
x1 Kinetik 1800
-Soon Too Be Walled
Fav Quote:
Keep in mind that lower current to your speakers doesn't mean less current through your power wire. The only reason it might (in almost all cases would) be less is the efficiency.
  • Who's Online   0 Members, 0 Anonymous, 504 Guests (See full list)
