i have a 2 x JL audio 12v3 dual coil.... any1 here use this subwoofer? and box wise, how do i get the most out of this subwoofer?
btw this sub will be powered by a kicker kx400.2....
thanks for the help :pardon:
HU: Kenwood DDX5034
front stage: Focal 165 v Slim component
back stage: Infiniti 652i
component amp: kenwood 4channel
sub amp: sony mono 800watts peak wired to 2 ohms
subwoofer: 3 12" Kenwood subs (from my old car)
its a toyota innova.... a SUV i think... the woofer is dual coil each 4 ohms....
HU: Kenwood DDX5034
opss sori hehe its 12w3 dual coil
HU: Kenwood DDX5034
H:15"
W:30"
D:15"
Port
H:13.5"
W:2"
D:20"
Tuned to 36hz
27" of port
subs up port back
Edited by zayres29
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
can i make it bigger or change the dimension, i have a space measured up, the maximum i can put in the back is W:40" H:17" D:21"... i was thinking of making a diamond shaped port. btw, what do u think about the amp i use, will that do the job?
HU: Kenwood DDX5034
that amp will be ok they could probably take a little more power but its probably not needed
you can do the box however you want i want just making suggestions just make sure you stay in the 32-36hz range with tuning and make sure you have enough port area
with the dimension u gave, thats around 3 ft3 of volume rite? what if i make it a 4ft3 volume? and who do i wire this dual? wire them to 4ohm and bridge it or wire each sub to 2 ohms to each channel?
Edited by zeus245
HU: Kenwood DDX5034
either of the ways you suggested you will get about the same power.
this is what i found for your amp
Dynamic Power Rating (measured at 14.4V):
Bridged Into A 4-Ohm Load: 435 watts x 1
Per Channel Into A 2-Ohm Load: 217 watts x 2
Per Channel Into A 4-Ohm Load: 150 watts x 2
Continuous Power Rating (measured at 13.8V):
Bridged Into A 4-Ohm Load: 400 watts x 1
Per Channel Into A 2-Ohm Load: 200 watts x 2
Per Channel Into A 4-Ohm Load: 100 watts x 2
  • Who's Online   0 Members, 0 Anonymous, 2907 Guests (See full list)
