:popcorn:
if you use one. and somehow it makes 100% of its rated power. youre gonna be getting 1500wRMS and all 8 subs need 1600wRMs so you'll be underpowering a tad. but i dont think it would be an issue.ill do some looking and see if i can find a diagram to wire them all down to 1 ohm
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=4&I=42#results
The top option is to wire down to .5 ohm. but in any case you're gonna need two amps to power all 8.
EDIT: actually if you wire 4 to 2 ohms. your amp will give you 800WRMS and 4 of your subs will require 800w RMS so just get another saz1500d and run the other 4 and you will be golden! :yahoo:
Edited by SPLVan
1999 Dodge Caravan
[TrashMobile]
8ga Power/Ground
AudioPipe APSM-1300 (subs)
Scosche 550 (mids/highs)
Boss 735UA Headunit
(2)Hifonics HFi12D4
Still Under Major Construction..
But that's also what I'm trying to see what's the final impedance of 8 dual 4 subs and the final impedance of 8 dual 2 subs.
i cant see why you cant wire them to whatever you want. 2 ohms 1 ohm. just need to find a diagram or do some reading on wiring in parallel. or series
1999 Dodge Caravan
[TrashMobile]
8ga Power/Ground
Boss 735UA Headunit
(2)Hifonics HFi12D4
  • Who's Online   0 Members, 0 Anonymous, 670 Guests (See full list)
