I have a 08 Lancer GTS that came with the Rockford Fosgate sound system, I have the line out converters connected correctly after the factory amp. The rear speakers sound mint, very clear, and loud. The front speakers are muddy not as high frequencies seem to come through. I would just wire my front speakers to the rear but then my gps, and Bluetooth wont work so that is not a possibility. It has been this way since I got the car, but I was thinking maybe the problem is the factory amp? Also I get a engine noise (higher frequency wine) in the front passenger side speakers. The speakers polarity is correct. Also with my volt meter I checked the output voltage on the factory amp front vs rear speaker outputs and the front voltage was low while the rear was much higher. Any help would be appreciated. All the speakers are 100% okay none are blown or defective.
Edited by xstingstreetx87
DONT MIND ME, IM JUST A DISRESPECTFUL PIECE OF SHIT.
Sounds like the rear is full range, but the front signal is lowpassed just for the midbass speaker.
Pac audio should sell a piece called a "add-a-amp" that will plug in right behind the deck. And give you 4ch out full range
Correct ray
My girls is the same setup cause front is components and rear are coax
Hahah damn cody
She ain't that sexy. I wouldn't even let her blow me. Those 10 pounds of make up would end up all over my crotch.
you dont find dubstep, dubstep finds you
hu: Pioneer MVH - P8300BT
mids: Alpine sps-600 all four corners
highs: Addictive Audio ECST25A,Memphis PR tweeters back
sub: 15 inch crossfire bmf
box: 4 cubes at 38 hz
amp: Rockford Fosgate Power 1000 25 To Life
140.7 on a non sealed trunk car with a five channel so far (old sub audiobahn aw1505q)
Build Log
http://www.stevemead...ima-56k-beware/
Feedback
http://www.stevemead...s-bfd-feedback/
Wut...you doubted me?
Come on luis...
Idk man... Working for hostes donuts from miguel lol jk
I wasnt doubting i was adding on to help
Idk if op has blown tweeters or low eq settings that he can hear his front tweeters
Hahah damn cody
Build Log
Feedback
Interesting, that makes sense, but if I used the PAC add a amp i dont think my gps, bluetooth, and stuff would work because that comes from the front speakers, i dont know though. Also trying to get into my dash will be fun haha 08 lancer gts
it looks like a pita, try to go to a evo forum and see if there is a thred on how to take it apart.
im too scared to touch my girls lancer lol
Hahah damn cody
Build Log
Feedback
deck comes out in about 2 minutes.
