Blown Sub?{need Help Wiring}-~-~video Added~-~-
Well make sure your not trading for a " box or rocks " if ya know what I mean ;)
ok I got the kicker solo-baric L7 and I have no idea how to wire it. it has a Coil 1(+.-) and a coil 2 (+,-) how do I wire this iv tried and cant get it to work
~REFS~
-CA.com-Gianotti(2 18" FI BTL D1) Slowd N Throwd(Wiring),Ebrunn(PC monitor),Rab(HK4000D)
-SMD.com-Nismofreak(Radar),BigP(Phone Headset),anonymous(Xbox360 Headset)
depends on what impedance it is (dual 2 or dual 4ohm) and depends on what ur amp is rated for...give more info plz
the sub is 4ohm
and my amp is american bass pro (mine is 600watt but it says vs-1404)
vs-1404
TWO CHANNEL BRIDGEABLE AMPLIFIER
MAXIMUM POWER OUTPUT
200W x 2CH (400W) @ 2 OHM
POWER OUTPUT:
85Wx2CH (@ 2OHM) LESS THEN 0.3% THD
55Wx2CH (@ 4OHM) LESS THEN 0.1% THD
MONO: 170Wx1CH (@ 4OHM) LESS THEN 0.3% THD
ALL MEASUREMENTS DONE @ 14.4VDC, 1KHz INPUT SIGNAL
FREQUENCY RESPONSE 20Hz-20KHz
2OHM CAPABLE IN STEREO MODE ONLY
THIS MODEL IS EQUIPED WITH:
LPF (LOW PASS FILTER) VARIABLE 50Hz-250Hz
HPF (HIGH PASS FILTER) VARIABLE 2KHz-10KHz
HIGH AND LOW ADJUSTABLE LEVEL INPUT
MOSFET DC-DC SWITCHING POWER SUPPLY
LED INDICATED POWER STATUS
BUILT IN PROTECTION AGAINST SHORT CIRCUIT AND HIGH TEMP
TRI-MODE SPEAKER CONNECTION READY
BASS BOOST (+5dB @ 100Hz)
AUTO POWER ON/OFF BY REMOTE (+12V)
DIMENSION: 11 1/8 (W) x 1 7/8 (H) x 8 (L)
~REFS~
looks like you need to wire it + to + and - to - on the sub............. that will get you a 2 ohm load.
I got it to make a scathcing noise. when I push down on it, it makes a type of scratching noise does this means its blown after i finsih mowing ima run it down to California customs or laws
~REFS~
if u hear a scratching noise when u push down on it that is probably about the coil beind f'd up...sounds like ur screwed...
He said when we traded that if i didnt like it we could trade back(he said he had never hooked it up but before he had heard it before he bought it. How much does it cost to get fixed?
~REFS~
Well if when you push on the cone and hear a scratch that is deff a blown coil....as for the L7's kicker does not sell a recone kit, only the solo X's. I beleive kicker charges $240 to recone a 15" L7 which is about the same price they are new. So i would trade back if not you got a useless sub on your hands.
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
1998 Cadillac Catera
SPLMAX CUP 2008 Fourth Place Overall
  • Who's Online   0 Members, 0 Anonymous, 1571 Guests (See full list)
