You need a 4 channel amp and a 2 channel amp. Need to be able to set a bandpass for the midrange, low pass for the mid bass, and high pass for the tweeter. Frequency depends on driver. Do either two amps with really good xover settings or a good processor.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
Ok so it is possible. Thanks for the response!
With the processor I would only need one 4 channel amp?
Edited by C.Sanchez.A
Click Links To View Build Logs
1994 - Mazda B3000 (Daily/Toy/Show)
2002 - Mazda Protege (Daily)
1995 - Hyundai Accent (R.I.P.)
1984 - Bronco II (Restoration Project)
Youtube Channel
No. Still a 4 channel and 6 channel. Each speaker has to have it's own power source and crossover settings. You would control the midbass by the amp alone setting the loquats filter between 500hz-1khz and the processor to control the midrange bandpass and tweeter highpass
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
you "could" use ur comp set as normal(passive), and hook your midrange to an amp/processor with bandpass capabilities. might be hard to blend them in with the comp set though... idk
4 channel amp -> comp set on 1+2, midrange on 3+4 (if your amp has bandpass capabilities there is no need for a processor.)
you would be running 4/6 passive + 2/6 active however.
idk if thats a good idea or not... i really have no experience in car audio but it is an idea for you to look into.
What if the component speakers already have their own xovers and alls I want to do is add a speaker to the set.
If they have their own x-overs than you can power them as you normally would. A good bandpass xover built into an amp will give you the flexibility you need. All you really need than is a 4 channel amp with all the fixins. That will allow you to run the components sets on two channels and the other 6.5" on the other two channels.
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
