C.Sanchez.A Posted May 11, 2011 Report Share Posted May 11, 2011 I have a paire of 6.5 components and want to add a mid rang speaker inbetween the mid bass and tweeter. How would I hook it up? Quote Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel Link to comment Share on other sites More sharing options...
C.Sanchez.A Posted May 12, 2011 Author Report Share Posted May 12, 2011 Supper / end of work bump! Quote Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel Link to comment Share on other sites More sharing options...
C.Sanchez.A Posted May 12, 2011 Author Report Share Posted May 12, 2011 C'mon no one can help... Maybe it needs to be moved to a more active section... Quote Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel Link to comment Share on other sites More sharing options...
C.Sanchez.A Posted May 13, 2011 Author Report Share Posted May 13, 2011 No one knows how I would be able to run this set up? Quote Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel Link to comment Share on other sites More sharing options...
Robert8252 Posted May 13, 2011 Report Share Posted May 13, 2011 You need a 4 channel amp and a 2 channel amp. Need to be able to set a bandpass for the midrange, low pass for the mid bass, and high pass for the tweeter. Frequency depends on driver. Do either two amps with really good xover settings or a good processor. Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff Link to comment Share on other sites More sharing options...
C.Sanchez.A Posted May 13, 2011 Author Report Share Posted May 13, 2011 (edited) Ok so it is possible. Thanks for the response! With the processor I would only need one 4 channel amp? Edited May 13, 2011 by C.Sanchez.A Quote Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel Link to comment Share on other sites More sharing options...
Robert8252 Posted May 13, 2011 Report Share Posted May 13, 2011 No. Still a 4 channel and 6 channel. Each speaker has to have it's own power source and crossover settings. You would control the midbass by the amp alone setting the loquats filter between 500hz-1khz and the processor to control the midrange bandpass and tweeter highpass Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff Link to comment Share on other sites More sharing options...
C.Sanchez.A Posted May 13, 2011 Author Report Share Posted May 13, 2011 What if the component speakers already have their own xovers and alls I want to do is add a speaker to the set. Quote Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel Link to comment Share on other sites More sharing options...
newb Posted May 13, 2011 Report Share Posted May 13, 2011 you "could" use ur comp set as normal(passive), and hook your midrange to an amp/processor with bandpass capabilities. might be hard to blend them in with the comp set though... idk 4 channel amp -> comp set on 1+2, midrange on 3+4 (if your amp has bandpass capabilities there is no need for a processor.) you would be running 4/6 passive + 2/6 active however. idk if thats a good idea or not... i really have no experience in car audio but it is an idea for you to look into. Quote Link to comment Share on other sites More sharing options...
Kevin M Posted May 15, 2011 Report Share Posted May 15, 2011 What if the component speakers already have their own xovers and alls I want to do is add a speaker to the set. If they have their own x-overs than you can power them as you normally would. A good bandpass xover built into an amp will give you the flexibility you need. All you really need than is a 4 channel amp with all the fixins. That will allow you to run the components sets on two channels and the other 6.5" on the other two channels. Quote 2005 Ford Focus zx4 AMT's and Planars 18" Infinite baffle Link to comment Share on other sites More sharing options...
