Need advice on spl build.
My friend and I have been working on an spl build to take to a competition coming up. We have an Audiopipe 30001D with a 15" FI BTL. Its in a 93' mazda mx-3. The box is 5 cubes tuned at 45hz. The car peaks at 50hz. The box has 45 degree bracing's in each corner. We have 1/0 running from the battery to a distro block, then 4 gauge to an optima red top then 4 gauge to amp. We are replacing the speaker wire with either 10 or 8 gauge. We also have been told to paint the inside of the box and silicone it. The amp was run at 2 ohms and we are considering doing a half ohm burp. The length from distro block to battery is about 3 feet then another 3 feet to the amp so theres about 6 feet of four gauge. The box will be wrapped in duct tape also. We hooked it up to a termlab today and got a 146.5 in the kick panel with driver door open and sunroof open. when everything was sealed we did around a 143.8.
Questions:
Will the audiopipe handle a .5ohm burp?
Wiring the sub to .5ohm isnt a problem but how would we plug the wires into the audiopipe?
Is there anything else we can do to gain db's?
Edited by ItsAJeepThing
45HZ??????
thats high as hell..................
why not some 38hz or lower??
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
45HZ??????
his car peaks at 50...
i honestly think you need a bit more battery to keep that audiopipe alive at .5
Edited by IH8PunkRok
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
45HZ??????
is he doing this system just for burps??
u thought it was for a daily driver
45HZ??????
did you read the first sentence or glance at what forum this is in?
anyway make every surface you are allowed to modify as smooth as possible. maybe try a new box with more port?
spl is just a test and retest thing. often times something that works for one does not work for another.
also try playing with your vents, visors and glovebox
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
We had it clamped the same day, the ohms rose to about 5 and it did only about ~1600 watts. So with impedence rise, if we did wire down to .5 ohm the amp really wouldnt ever see it. Is it still a bad idea?
no actually. it seems to make the most sense to try it
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
This is the OPs buddy. The port is pretty large the way it is. I don't remember the port area off the top of my head but I know its more than enough for an SPL setup.
I had another thought. If we run the ap3000d, we must compete in the stock 601-1800 class. We have an Ap1500 that we could use instead dropping us down to the stock 0-600 class. From here we could run the 1500 at .5 ohm to stay competitive. Thoughts?
Edited by MatthewMartin
  • Who's Online   1 Member, 0 Anonymous, 1116 Guests (See full list)
