jizazz12 Posted May 16, 2011 Report Posted May 16, 2011 O.k. as the title says, I have two d.c. LVL4 15's with Lvl 5 upgrade in my o'7 impala, box is rite at 6 cubes net tunned to 32 with four four inch aeros ( on the small side i know) but they sound great . When i was building the box i was going to put six four inch aeros in it but just couldn't get that many in, i have the subs firing into the backseat and the ports through the rear deck and just didn't have enough room for the six there. i know i can get these sounding even better than they already do. i need more port so i was wondering if could replace the aeros with a slot port to give the added port that i need without building another box? I have no experience with slot ports so i am going to need some help with this from someone who knows what there doing, I want to upgrade to Xls and when i do i will go ahead and build a new box but for rite now i'm trying to work with what i have. I have 4" from top of box to the rear deck , aeros are partly external would have to do the same with new port. I have 36" W x 27.5" D and like i said 4" from top of box to rear deck. Subs are being powered by Crescendo 3wkp. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
jizazz12 Posted May 17, 2011 Author Report Posted May 17, 2011 Just need some help figuring out the measurements for a square port for this box, help please. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
mzenon88 Posted May 18, 2011 Report Posted May 18, 2011 Pi* radius* height will give you the internal volume of the aeros
tlee2 Posted May 18, 2011 Report Posted May 18, 2011 You gonna add a external slot port? The box will be too small if you try to add one on the inside 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
jizazz12 Posted May 18, 2011 Author Report Posted May 18, 2011 Yes sir thats what i was planning on doing remove the aeros and replace with a slot/square port, box sounds good with the aeros now but i need more port i know these can get lower. want to put an external port through the rear deck. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
jizazz12 Posted May 18, 2011 Author Report Posted May 18, 2011 Pi* radius* height will give you the internal volume of the aeros Thanks for the info but looking to replace aeros that are in box now with a slot/square port . 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
-Hobby- Posted May 18, 2011 Report Posted May 18, 2011 The areos take up less airspace than a slot port would. The slot port would also be larger because your going to need more sq in of port to do what an aero port does with less sq in. Your already on the small side as far as your net cubes are concerned. Would be better off designing a new box because your net cubes are gonna take a hit when you try to put a slot port in that thing.
jizazz12 Posted May 18, 2011 Author Report Posted May 18, 2011 Thats why i wanted to get a few other opinions before i ripped this box out and started over, i would like to try and use what i have but if i don't have enough room to make the change with an external port than i will start re designing the box. just thought i would be able to pull it off with an external port seeing how my internal net would stay ware it is. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
tlee2 Posted May 20, 2011 Report Posted May 20, 2011 Yeah you would be better off with a new design. If you only have 4 inches from top of box to rear deck your not gonna be able to get a long enough port for a low tune unless you sacrifice a bunch of port area. That would be no good 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
