I got alternator noise and need some help!
OK, so heres the scenario. Me and a friend redid my system this past week and I now have alternator noise. I have done everything except running the source unit power directly to the battery, grounding the RCA's, and a power line noise filter. The amplifier is a brand new powerbass ASA 400.4. Note that the amps were in the trunk before and all the wires were ran together per the installer that put them in and I had no noise at that time, but that was the old amp that got 2 channels burnt up. We had to redo all the wiring due to a new box and amp rack and we got alternator noise for free. Any input would be greatly appreciated!
Kenwood Excelon KDX-693 Head Unit
Kinetik HC600
Powerbass 6.75's in front doors
Powerbass 6.75's in rear deck
Powerbass 1000.1D
Powerbass 400.4
2 SA-12 inch Sundown Audio Subs
0 gauge Power Wire and Big 3
Custom Amp Rack
Code Alarm with remote start
Stinger Digital Volt Meter
My build log http://www.stevemeadedesigns.com/board/topic/51869-1996-chevy-blazer-build/
My youtube channel http://www.youtube.com/user/kanesdisciple
Anyone???
Kinetik HC600
Powerbass 1000.1D
Powerbass 400.4
Custom Amp Rack
Also make sure your RCAs are not ran along the power wires.
First System
2002 Impala LS 3.8L V6, 128,365k miles.
Alternator: DC Power 190Amp H/O Alternator
Headunit: Kenwood KDC-BT945U.
Speakers: MBQuart 6.5" Comps, 6x9 3-way.
Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w
Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm.
Box: 3.1cuft box tuned to 33hz. sealed off to cabin
Big 3- done with all Knukonceptz KCA 0 gauge.
Don't drop below 14.1v at full tilt. :)
If you can unplug the RCAs from the amp and the noise goes away, then a PAC ground loop isolator is normally a quick easy fix if all else fails. . .
Edited by bkolfo4
Current system:
Previous systems:
Head unit is a Kenwood Excelon, RCA's go down the passenger side and the power wire plus remote wire go down the drivers side. The amp was first grounded to the Kinetic in the trunk and yesterday we moved the ground to a seatbelt bolt after grinding it to bare metal and made it under 18 inches and the noise is still there. After work today we r going to try a noise filter at the head unit first and if that don't work then we will try a ground loop isolater!
Kinetik HC600
Powerbass 1000.1D
Powerbass 400.4
Custom Amp Rack
Seatbelt bolts are not good grounds. Ground to the strut tower(or run a ground to the front battery). Also check the RCA's and make sure the ends are not broken.
Edited by Rebel4055
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
I know the seatbelt bolt isn't the best ground, but I had my main ground on a seatbelt bolt in my blazer and never had one problem with it. But ya we can try the strut tower for a ground, thanks!
Kinetik HC600
Powerbass 1000.1D
Powerbass 400.4
Custom Amp Rack
  • Who's Online   0 Members, 0 Anonymous, 835 Guests (See full list)
