Where to start, well i guess listing the equip is a good place lol
My friend has a '99 nissan maxima 4 door.
1 hifonics ZXI 80.4 4 channel amp
1 Verge (crap) 12" subwoofer
1.75 cubic ft box.
So heres the problem. simply the sub doesnt play.
now ive done some diag.
1. The amp lights up and is not in protect mode.
2. The sub plays fine when i connect it to my bench amp
3. The sub used to play fine until i guess he connected a rockford fosgate p2 12 with 1 blown coil.
4. The ground, turn on wire, and + wire are all fine and read ~13v as they should.
5. I thought maybe there was a problem with signal actually getting to the amp so i pulled my rca to headphone out of my room and plugged it directly into the inputs on the amp and played music through my phone.
6. No matter what channels i use, i cant get the sub to play at all.
I would just pass it off as a bad amp but when i switch the hpf/lpf switch, the sub does make a small pop if you will.
I wanted to see what you guys thought.
Brandon
Since you've already figured out the h/u and rca cords are fine its either the speaker wire, amp or sub thats left to rule out. Try the sub on something else that is in known working order, check that the amp is putting out voltage with a DMM on the speaker outputs and check the the speaker wire isn't crushed, cut or damaged in any way.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I have same amp nothing worry
2003 Grand AM GTELECTRICAL SYSTEMAlternatorstockBatteryFront s3400back d3100Wireinglots of 0gaHEAD UNITpionner 7500xSPEAKERS(4)Prv 6mb200(2)prv 10mr1000AMPLIFIRLS(1)Zxi80.4(2)Brx1200.4SUBWOOFER(2) MTX 9500BOX3.41 cuft 63sq port 34hzLINKSYoutube.com/reggieb198895
...huh?
and Skullz, the sub plays just fine when its connected to something else.
and thanks, i will go check it with a dmm.
  • Who's Online   0 Members, 0 Anonymous, 4008 Guests (See full list)
