sps1989 Posted May 21, 2011 Report Share Posted May 21, 2011 what would be the best ported box size for this sub? i only have one at the moment and would like to do a few competitions with it. i want the most dbs as possible. if you want you can just give me the cubic feet and the tuning hz and i can do the rest Link to comment Share on other sites More sharing options...
matt402 Posted May 21, 2011 Report Share Posted May 21, 2011 how much power are u going to run on it? Link to comment Share on other sites More sharing options...
sps1989 Posted May 21, 2011 Author Report Share Posted May 21, 2011 how much power are u going to run on it? i have 800 w on it right now but am getting another amp soon that is at least 1000 w but im gonna try to stay as close to rms as i can unless its better to push it a little more Link to comment Share on other sites More sharing options...
matt402 Posted May 22, 2011 Report Share Posted May 22, 2011 id go with 2 cubes. what type of music do u listen to mostly? Link to comment Share on other sites More sharing options...
sps1989 Posted May 22, 2011 Author Report Share Posted May 22, 2011 id go with 2 cubes. what type of music do u listen to mostly? i listen to pretty much everything but i really like the bass in rap/hip hop. and is 2 cubes including the sub and port or just the port or what. i have it in a box that is 2.3 cubes without the sub and tuned to 33 hz and it hits the lows great but doesnt really have the dbs. my highest was only 134.0 *EDIT* my box is 1.905 with the sub in it and including the port. and its tuned to roughly 33.69 hz Link to comment Share on other sites More sharing options...
RAM_Designs Posted May 22, 2011 Report Share Posted May 22, 2011 Tune higher and go with a bigger box if you want a burp box using RMS power. If you still want to play music with it then just up the tuning a little to get more output without killing your low-end response. If you actually want to go to competitions, then you're going to need to build a burp box to get the most out of your situation(assuming the class you're in uses test-tone burps). What vehicle is this in? Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011... Link to comment Share on other sites More sharing options...
sps1989 Posted May 22, 2011 Author Report Share Posted May 22, 2011 Tune higher and go with a bigger box if you want a burp box using RMS power. If you still want to play music with it then just up the tuning a little to get more output without killing your low-end response. If you actually want to go to competitions, then you're going to need to build a burp box to get the most out of your situation(assuming the class you're in uses test-tone burps). What vehicle is this in? ok how much bigger and to what hz? and its in a 02 silverado 1500hd 4 door Link to comment Share on other sites More sharing options...
sps1989 Posted May 24, 2011 Author Report Share Posted May 24, 2011 any other suggestions? Link to comment Share on other sites More sharing options...
sps1989 Posted May 26, 2011 Author Report Share Posted May 26, 2011 my truck has a res freq of about 58 hz. what should i tune my box to? Link to comment Share on other sites More sharing options...
