Jmoney2544 Posted May 21, 2011 Report Posted May 21, 2011 Hey, Im planning on doing a trunk build, and i can get around 8 cubes in it after all displacemnts, but the problem is that my width is 36" so i can only get a 5" port width at max. (cause im planning on 15's) the port would be 5x15.5 so its around eighty inches in a 8 cube box. thats only 10" per cube. can any sub work in these permaeters? or would i be better off building a box for 2 12's with optimal box volume and optimal port area? planning on running 1 aq2200 Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
Supercharged DCs Posted May 21, 2011 Report Posted May 21, 2011 If your width of the box is 36", why are you confined to 5" max? Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
Jmoney2544 Posted May 21, 2011 Author Report Posted May 21, 2011 If your width of the box is 36", why are you confined to 5" max? 15's, sry Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
