So my amp has never had any issues. Directed d2400. I grabbed the dmm to head out to the garage to test voltage. I turn on the car, and no sound from the sub. Upon closer inspection, I see the amp is in protect mode. Wtf? What would cause this? I mean, the amp never cut out or anything while playing.
It's powering a dc lvl 4 d2 wired to 1 ohm.
Something is causing it to protect lol.
Check fuses, remote wire for pinches, power wire for bare spots grounding out.
Also, check voltage at your power terminals at the amp.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Is the amp 1 ohm stable? Or maybe low voltage?
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
All fuses are correct size? Just trying to ask the simplest first b/c it might be something simple. it happens. Can you take the amp top plate off to look at the internals
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
So, I emptied EVERYTHING out of the trunk, so I could get into the spare tire well so I could get to the blade fuse by the battery. Took it out, looked fine. Reinstalled, and now protect mode is off, and it runs like a champ again. Wtf?
Something had to be loose or just a faulty connection
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
It happens i always do a check once a week to make sure evrythings tight
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
