i wish i did but i dont remember if its special resin or just regular run of the mill fiberglass resin. someone will prolly know though so just wait for an answer
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Thanks for the info you could give me
Basshead-in-Training
I made a sub all out of foamboard and i use the coil and magnet from an old 12 i had it worked fine until the coil seperated from my cone then it just rattled now i have to wait until i get some more super glue to finish my rebuild on it. I made the cone stronger by getting rid of the foamboard supports and using popsicle sticks, and now i just have to glue it back together and it'll be ready to go.
The Midget Looks Into Your Soul
2008 Dodge am 3500HD with the 6.7 Cummins
Race Me tuner, dpf deleted
kenwood double din
cheap walmart speakers for now(infinity reference comps comps coming soon)
2 kicker L5's in a ported box of unknown tuning lol(soon to be changed)
Power acoustic 1500.1 on the subs (for now)
CA Glue is just superglue, btw.
edit
here's a trick if you have some gap issues while gluing:
Edited by STEvil
Hammerdown... 1%
I tried superglue for the coil, and now I know that superglue vaporizes.
What do you mean you use popsickle sticks to support the cone?? DO you mean you used them to support the foamboard cone?
I used hot glue for all my constucting, (besides the wood) but after I think about it super glue is probably more lightweight.
Edited by joshywb121
