KnockinthaStreetzof608 Posted May 25, 2011 Report Posted May 25, 2011 well i got mostly everything ran in my car my ,2run of 1/0 gauge passanger side ,aq gainknob rcas driver side well i still have my remote wire and my stinger volt meter let to run and in my small as mustang there no room really to run more wire on my passanger side of the car, will i get any interference if i run m stinger voltmeter and my remote wires on the rca side of my car? CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED!
Emmet Posted May 25, 2011 Report Posted May 25, 2011 well i got mostly everything ran in my car my ,2run of 1/0 gauge passanger side ,aq gainknob rcas driver side well i still have my remote wire and my stinger volt meter let to run and in my small as mustang there no room really to run more wire on my passanger side of the car, will i get any interference if i run m stinger voltmeter and my remote wires on the rca side of my car? You shouldnt. Aslong as there isnt any major power running through the cables you should be fine, that voltmeter wouldnt use that much power, it would only be the power cables running from your batt to rear that would cause interference in the RCA`s. i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah.. You want this to happen to you? Give decent handshakes people. I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
KnockinthaStreetzof608 Posted May 25, 2011 Author Report Posted May 25, 2011 well i got mostly everything ran in my car my ,2run of 1/0 gauge passanger side ,aq gainknob rcas driver side well i still have my remote wire and my stinger volt meter let to run and in my small as mustang there no room really to run more wire on my passanger side of the car, will i get any interference if i run m stinger voltmeter and my remote wires on the rca side of my car? You shouldnt. Aslong as there isnt any major power running through the cables you should be fine, that voltmeter wouldnt use that much power, it would only be the power cables running from your batt to rear that would cause interference in the RCA`s. yea i thoughed so, just wanted to clear it up thanks CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED!
