I have a 1999 Plymouth Breeze 4-cyl. 2.0L. My problem is that my car is supposed to get around 26 city and 28 highway MPG and for the first 9 months i had it i got that. But recently my gas mileage has been lowering majorly. my last take averaged at 17.3 mpg and i have been driving it carefully(kept under 2000 rpm-ish). I have brand new oil in it which is Castrol Edge with Titanium technology, so its pretty much top of the line synthetic oil. The car has 91,XXX miles on it and has been driven by my grandma its whole life till it was given to me, which i also drove it with care. If anyone has any other ideas on how i could fix my gas mileage problem tell me because gas is expensive nowadays and i cant afford it at the moment.
2x Sundown Audio SA-15's nuff said for my little old car
1999 Plymouth Breeze Build Log
Posted (edited)
No check engine light? does it mis fire? I would check out your O2 sensors, maybe give it a tune up new plugs wires and distributer (sp?) cap. maybe fuel filter too.
Edited by Dan2427
2003 GMC Yukon Denali
Alpine CDA 117
Redoing Mids/Highs
4 Runs of 1/0 Knukonceptz 2+, 2-
4 Deka 9A31's in back (Stock underhood) 250 amp Alt.
AQ20K
2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
Posted (edited)
oil, tire pressure. check your filters. is it fuel injected?
Edited by bass_stalker
if its running alittle bad you might have clogged injectors or you might have old plugs that need to be replaced
try your plugs wires and cap first. Do you know if they ever been changed
Alpine CDA 117
Redoing Mids/Highs
AQ20K
maybe someone else that knows a little more could answer this, but maybe if he swithched gas grades or different gas brand as before, could that also affect gas mileage?
most likely not. all the octane is, is a measure of how hard it is to ignite the gas
  • Who's Online   0 Members, 0 Anonymous, 8775 Guests (See full list)
