Here is a short video of my setup. Hard to see if I need to I will take it during the day so you can see it better. I thought this would hit a tad bit harder. I have an epic 160 doing the metering. My current setup is
Sony HU
Epic-160 not used during test except the spl meter
Rockford Fosgate T30001bd
3 Rockford Fosgate T2's 15''
I thought the box was tuned to 35hz
My question is should I get another box so I can get it louder? Also During the song it cuts out at around 60 cycles. What ever that is in hertz I dont know. I play the song Hoods run down by lil whyte and in the intro. I dont pick up the lows right before the song starts. Any help appreciated
Here is a vid.
http://s79.photobucket.com/albums/j130/lee...nt=MOV02726.flv
how accurate is that meter???? and did u ever meter it on a termlab
new toy
97 chevy s10 ext cab
bagged
22s
system (coming soon )
4 soundstream t4-15s walled
2 concept 2410 mono amps
REFS
http://www.stevemeadedesigns.com/board/ind...hl=cartunez2004
http://caraudio.com/forum/showthread.php?t...ht=LOUDCARTUNEZ
Cycles=hertz=hz.
same thing.
Need some better shots of your box, too dark in the vid.
"You thought" is was tuned to 32hz?..based on what info/specs? CFT/port dimensions etc please.
that IS slightly low for that number of subs/size and power. 3-T2 15's off 3kw "should" be louder but your box is the key to sucess or failure in this case.
I pull about the same numbers on the same mic in my Integra w/ 4-12's sealed off about 1200-1400rms.
If it doesn't play 60hz....does it play Other frequencies ABOVE 60hz? or just no/minimal output above 60hz?
If so I say check ur xover settings on the amp.
~2cents
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
so how accurate are those meters compared to a term lab
new toy
bagged
22s
REFS
o ok this meter is suppose to be only .5 db off so i think ill buy this just to do some testing before next season
http://cgi.ebay.com/186-db-SPL-SOUND-LEVEL...1QQcmdZViewItem
new toy
bagged
22s
REFS
First flip your box over so that the ports are on the bottom facing the rear and see what happens. Next build yourself a new box. I'm figuring you have roughly 3ft of airspace & 28" of port area per sub. Go for 3.5ft w/ 50in of port per sub tuned to 32-35hz and you'll be much happier. Do you know if your subs are d2s or d4s?
they are d2's so i think amp is runing at 1.33ohms or 1.34 something to that. So firing them back towards doors and how do i figure out tuning. I have built a box before for 2 15'' hx2 powers that was approx 9.6 cubes before. I think I can build another one. Just how do I figure out tuning. Think if I built a bigger box I can add some more db's?
  • Who's Online   0 Members, 0 Anonymous, 2089 Guests (See full list)
