alpine cda-9886 help
i got an alpine cda-9886 i know its pretty popular my problem is when i hit source to go into ipod it will go through tuner, cd, usb , aux, but wont go into ipod it will just skip right over it i tried resetting it and unplugging the battery and no luck i did not get this new so i dont have installation disc or upgrade
i took out the headunit and it does have the ipod cable hooked up the one with blue plug at the end its this cable http://www.alpine-usa.com/product/view/kce-422i/
Edited by bassHZ
I probably isn't recognizing hour iPod, mine does the thing, I just hooked it up to the AUX and it works fine. But if u want to use the hu controls put your music in a USB drive I did that too
i tried hooking up my ipod thru usb instead and said error ama try my thumg drive next
reset your ipod
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
try that first. If not you might have a bad cable. r port
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
tried reseting my ipod still nothing and reset head unit again but u know as ur going thru ur sources cd, tuner, then usb then it goes back to tuner as in the ipod source isnt there
its not recognizing it the port is either bad or the cable is bad/not making a solid connection.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
