30Hz.wav Posted June 2, 2011 Report Share Posted June 2, 2011 I have this amp, BRZ24001D http://www.onlinecarstereo.com/CarAudio/p_23925_Hifonics_BRZ24001D.aspx 2400 x 1 @ 1 ohms I am wanting to try DC Audio as I always hear good things about them. So should I do, 2 15" Lvl 4's? or 2 15" Lvl 4XL's? or 1 15" Lvl 5? I am confused as to which combo to go with on this amp. Any help is appreciated! Quote Link to comment Share on other sites More sharing options...
Sammitch0 Posted June 2, 2011 Report Share Posted June 2, 2011 Any reason for not going with an 18"? 2400RMS won't even touch to 4 XL's they require about 2k each. I'd say a single 18" Level 5 or the two 15" level 4's. Unless you plan on getting another amplifier in that case the Level 5 and two Level 4 XL's. Quote Grand Cherokee Team Backwoods Bumpers DC 15" Level 3's /w 4 Coils Pioneer deh4200ub Pioneer 3-ways Pioneer Tweeters Pioneer GM-D9500F Audiopipe 1500.1D @ 14.4v Clarion Equalizer Knuconeptz Kollosus 0ga Knuconpetz Kollosus 4ga Coming Soon: 270xp / xs1200 Link to comment Share on other sites More sharing options...
Louisiana Bass Posted June 2, 2011 Report Share Posted June 2, 2011 2 lv4 would be all you need for that power. Quote N8. No homo...unless you want there to be. Link to comment Share on other sites More sharing options...
Supercharged DCs Posted June 2, 2011 Report Share Posted June 2, 2011 Agreed, two Lv4 15s or one Lv4 XL 18 would be good on that power. Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012. Link to comment Share on other sites More sharing options...
30Hz.wav Posted June 2, 2011 Author Report Share Posted June 2, 2011 Probably going to do 2 15" Level 4's. Reason being for no 18, is it won't fit inside the trunk. I would do 2 amps on 2 Lvl 4XL's but I don't want electrical to break the bank. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
Supercharged DCs Posted June 2, 2011 Report Share Posted June 2, 2011 If you don't mind me asking, will you be sealed off firing forward into the cab? If not, I doubt you have the proper airspace for 2 15s just in the trunk Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012. Link to comment Share on other sites More sharing options...
30Hz.wav Posted June 2, 2011 Author Report Share Posted June 2, 2011 If you don't mind me asking, will you be sealed off firing forward into the cab? If not, I doubt you have the proper airspace for 2 15s just in the trunk Firing into the cab, already measured, and 6 cubes will fit, just won't be easy. Quote Link to comment Share on other sites More sharing options...
Supercharged DCs Posted June 2, 2011 Report Share Posted June 2, 2011 6 cubes isn't really ideal for 2 15s mate, unless your really overpowering them. Is that before or after displacements? I'm assuming it's before, since you couldn't know woofer displacement because you hadn't chosen a sub yet. Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012. Link to comment Share on other sites More sharing options...
Louisiana Bass Posted June 2, 2011 Report Share Posted June 2, 2011 Or port displacement. Mate, you'd be better off going with two 12"s. Quote N8. No homo...unless you want there to be. Link to comment Share on other sites More sharing options...
mrd6 Posted June 3, 2011 Report Share Posted June 3, 2011 ^^This Youll be much happier with smaller subs in the right enclosure than larger subs in too small of a box Quote My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL Link to comment Share on other sites More sharing options...
