I need help with an amp.
SkylarDunn
So, a buddy comes by yesterday, tells me his subs "aint bumpin", so i pull out his box, and get to the amp, it powers on, it looks fine, the green LED is on indication alls well in crunchville, yet, has no output, so i decided to hook it up in my grandfathers suburban and test it. This amp, is a crunch 1400.2, does maybe 700w @ 4 ohms bridged, but i had it wired to about 3 ohms before rise, i thought that would be fine, same deal hooked it up, CRUNCH light is blue as sh*t, green indicator light is on, hooked the DMM up to the terminals, no output whatsoever.
any idea what i could be? uploading pics ofthe board right now. nothing looks burned, i have the skills to repair it, but i have no idea what the problem might be. any help here guys? thanks.
also, he said he was driving down a gravel road, bumpin it a little, then it all of the sudden cut out. i know this guy, and he doesnt really play it loud, so i cant figure out what the problem might be.
Getting bass into the cabin of a W124 mercedes is impossible.
Current setup:
Temp 1999 panasonic HU
rockford 300.2 for fronts
rockford 200.2 for rears
rockford 400.1 for sub
Leaning towards a 8" in an exponential horn
DAMN YOU GERMANS AND YOUR 5" SPEAKERS!
Current setup:
Any cold solder joints? Does it have any interior pico fuses?
Over a bumpy road if it wasn;t bolted down well it could have shaken a FET, and transformer coil or any other number of items loose. You;d need it's circuit diagrams to follow it through for continuity to really trace it.
Big 3 with 1/0 welding cable, dual runs of 1/0 and 2gua F-R
DD 2512 D2 powered by Audioque 1200d at 1ohm, 2.5ft^3 ported to 36Hz
Boston SX 6.0 comps powered by Phoenix Gold M50 for front stage
Silver Flute 8" midbass in doors powered by Alpine 3539
Alpine CDA-117 HU
  • Who's Online   1 Member, 0 Anonymous, 683 Guests (See full list)
