HELP Alpine PDX-M12 with 2 SWR-T12
ddog199
Isn't it better to run 4 ohms? I would like to run 2 swr-t12's at 600rms at 4 ohms off this one amp. Is it possible?
You likely wouldn't hear the difference. For your purposes, it doesn't matter.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
I'm sorry but I don't understand how it works... So there is no way with this amp to run 2 swr-t12 subs at 600rms @4 ohms
no. It is physically impossible.
If there are 2 ohm versions of that sub, then yes, you can buy those and run them at 4 ohms. But you can't run 2 4 ohm subs at 4 ohms.
Run them at 2 ohms. Be happy.
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
Usually at higher impedances there are lower THD values. But as mentioned you wouldn't hear the difference.
If you want the amplifier to see a 4 ohms load. The only way you can do that is by having one amp per woofer.
I guess I should have stated "with the equipment you have/are planning to buy".
Regardless, why are you so resistant to running that amplifier at 2 ohms?
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
You can achieve the same goal with one amplifier. But if you insist on running full alpine and a 4 ohms load you can buy two PDX-M6's. That route would probably end up costing more money.
oh boy... so you plan on spending all the money on a pdx only to try to use it the way it was specifically designed not to do? if all you want is 600w at 4ohm you need a different amp, and different subs. so rethink your build.
'splain Lucy.
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
'splain Lucy.
regular amp does less power at higher ohm loads. the pdx was designed to do the same power.
  • Who's Online   0 Members, 0 Anonymous, 681 Guests (See full list)
