Home Theatre Sub Box - 12" P3 = = Rebuild!
Tuning to the 20-29hz range will offer an unparallelled bass response, however you will experience a significant loss in sensitivity. Also, tuning a box for a woofer that cannot safely operate at those frequencies will have a detrimental effect on the woofer. Most likely, you will destroy the woofer.
If you are set on using those Audiobahn's, I would tune to 30hz exact. The woofers are not reccommended for use below 28hz. Effeciency is not too bad at 91db/w/m, however I believe that there are better choices for your system in the market. You need a high effeciency woofer with moderate xmax, low to moderate power handling and large piston area. May I suggest the brand P.Audio? They manufacture excellent loudspeakers well suited to your application.
What ever path you take, I wish you the best of luck with your build.
Cheers,
Mick
Work;
DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS Venice
Meyer Sound CQ-1's, CQ-2's, PSW-2's
RAMSA Monitor Amplifiers
P.Audio Monitors
BSS OMNIDRIVE and Soundweb
DBX 231 and Klark Teknik DN360 EQ's
RCF TT22A
RCF ART320
maybe even TB subs.
225HP 1996 S-Dime
JVC KD-G820
Crunch PZi 2250 powering Two Ascendant Audio Assassin 8s wired to 2 ohm at 225W RMS 2.26CF @ 36.4Hz 43.5 square inches of port with 45's
Kicker ZX350.4 powering CDT CL-61A's with TW-24 Tweeters
Contact me:
AIM: Necromancer Ku
YIM: Ku_Karukasa
MSN: [email protected]
Tang Band woofers would be an excellent choice in this situation. May I reccommend the neodymium range of woofers?
Cheers,
Mick
Work;
P.Audio Monitors
RCF TT22A
RCF ART320
I just finished building a 6th order series tuned enclosure for a yamaha 6" sub off 20 watts. Threw it in a couple vehicle's and this thing wangs. It was louder (only a little) than a 10" poineer off 100 watts in a 4th order! Home audio guys get pretty crazy into enclosure's, take a look around
so this is going to be my home theatre sub!! =D lol..
just need some designs now!!! =D
Nothing too crazy, something simple with less cuts lol. i hate using the jigsaw
06 SCION tC
take look around where??
06 SCION tC
diysubwoofers.org is where i learned everything about home audio
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
