Home Theatre Sub Box - 12" P3 = = Rebuild!
u need this
http://www.partsexpress.com/pe/showdetl.cf...tnumber=302-605
470w in 8ohm load
itll work perfect with that sub
not cheap but as i said b4...
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
wow.. uh, can you find something cheaper, i dont care if it wont power it to its max, lol..
how about...is there a way that I can power a car amp somehow from a wall socket or somethng... anything... lol.. I have some wall plugs i could cut, if i put positive to pos and negative to neg would it power it? would that be smart to do? idk.. so little advice or CHEAPER direction, for now I'll get me a crossover from walmart or unless you can show me exactly type of crossover i'd need... cuz i can push about 100 watts from my stereo amplifier, its meant for 4 speakers.
and only 2 are hooked right now, i could always use the OTHER two for this sub...? if i used one channel for one voice coil and the other channel for another coil? would that power it well? I could always try it lol.. but i'm guessing would be best to run only one channel right..?
06 SCION tC
thats why i said a plate amp would be easier
if u put a car amp into a wall socket it would explode, think about it normally car amps get 14v a wall socket puts out 120v not smart
ill see if i can find a good cheaper one
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
this one will give u 150w @ 8 ohms it says its 2 ohm stable though so u might be able to do sumthin with that (400+ w?)
http://www.partsexpress.com/pe/showdetl.cf...tnumber=302-614
i have 100w into a 10" sub and its loud
it should work pretty well
and this crossover should work (u found it) cause this amp has a low pass cut out which is gay but using this should work
http://cgi.ebay.com/DIAMOND-2-WAY-STEREO-P...6QQcmdZViewItem
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
