Alright, for the past 6 months or so I've been running a Rockford P3 Shallow mount in my 2001 Mazda Protege because I used to have it in my truck, but the truck got destroyed , so I've been dealing with this sub for now, I finally have the money to add another Sub to my system, but I'm afraid if I add the sub I want to, it will strain my amp. So Here's the Question...
I'm currently using this amp:
Polkaudio 880 Monoblock Amplifier
http://www.polkaudio.com/caraudio/pa/index.php?s=pa880_1
And This is the Sub I'm Using:
Rockford P3S Shallow Mount Subwoofer
http://www.crutchfield.com/s_575P3LS12/Rockford-Fosgate-P3L-S12.html?tp=112
Is It possible for Me to add this sub to my system without needing to purchase another Amplifier?
12" Alpine Type R SWR-1243D
http://www.crutchfield.com/s_500SWR1243/Alpine-SWR-1243D.html?search=alpine+type+r
Here's the Specs on the Amplifier and the Two Subwoofers:
PA880 Monoblock Amplifier:
300 Watts x 1 (4 Ohm), 500 watts x 1 (2 Ohm). CEA-2006 compliant specifications for true, accurate power ratings.
800 watts x 1 (2 ohm) dynamic power.
Rockford P3L-S12 Shallow Subwoofer:
Frequency Response 43-250 Hz
Power Range (Watts RMS) 100-400
Maximum Wattage 800
Sensitivity 86 dB
Impedance 4 ohms
And The Subwoofer I'd like to Add:
Alpine Type-R SWR-1242D 12" Subwoofer
requency response: 24-200 Hz
power handling: 300-600 watts RMS (300 watts per coil)
peak power: 1,800 watts
sensitivity: 85 dB
Impedance 4 ohms
Please Help me out here guys, I'd like to Add This Sub :D
If Both these Subwoofers wont Run off this 1 Amp, Please Tell me an Amp that will push both of the Subwoofers Nicely.
Thanks,
-Dominic
Edited by DominicT
the amp would be fine, how ever it is not good to use those subs together. you will get a lot of weird noises and not a whole lot of bass when you use non matching subs
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
Well I don't Know anyone who'd take the Shallow mount off my hands, so thats why I was planning on keeping it.
What Do you mean by weird noises?
Edited by DominicT
You should run 2 identical subwoofers. so either keep the rockford and get another or sell it and get two of the type R's. if your getting the type R's i would get a bigger amp in the 1200 watt range for example audioque 1200d.
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
like you will hear the subs cone it self moving around and hear air moving
rockford should be easy sell, I'd buy 2 alpines they will be find on your power.
Korey, wouldn't that only be the case if they were in the same box? I'd be running them with separate boxes, Since the Shallow Fits Nicely right behind my Back seat in the factory box from fosgate.
nope it will be even in separate boxes unless you cross them over to play different frequencies. it's not really worth trying to run both.
not really but it's 100% pointless to do and you will be the same exact same loudness as you are now
  • Who's Online   0 Members, 0 Anonymous, 1561 Guests (See full list)
