Can someone sketch my box?
I used torres box tuning calculator and it gives me the cutouts:
Top:21'' x 28''
Bottom:21'' x 28''
Sides:21'' x 28''
Front/back:21'' x 28''
Port top/bottom:3.5'' x 14.25''
Port sides:10.5'' x 14.25''
what will my box look like wen built?
2003 rsx:Alpine CDE-102Fosgate P300-1Fosgate P1 6.5"s15" Re SRX
Those dimensions confuse me. I'm not sure how it would go. Can you put up a screen shot of your box design in the calculator?
Need Test Tones/Sine Waves? Click Here!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Pioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE Audio
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Hit me up on Facebook, if you want
What side is the port going on? the long side or the short side? and is it going to be in the middle or on the end? And also, are the subs to be on the top or the back?
I'm guessing it's a sub back - port back?
My Saab 9000 build
I want the sub up if thats what you mean bye the long side and port going on the back , I basically just want to make sure the sizes that is tells me to cut the peices are right and what it looks like.
How many common port walls though? You didn't enter that into the calculator, that would mean it'd be an independent port, not connected to any walls. Anyway... Here you go.
could be like this:
Cutouts would be;
2 - 10.5 x 21 - Sides
2 - 30 x 21 - Top And Bottom
1 - 28.5 x 10.5 - Front (side without port)
1 - 26.5 x 10.5 - Back (side with port)
1 - 10.5 x 14.25 - Port wall
Could be like this:
2 - 28.5 x 10.5 - Front And Back
1 - 12 x 14.25 - Top Port Wall
2 - 2 x 14.25 - Port Side Walls
Hell it could be like this:
2 - 12 x 14.25 - Top And Bottom Port Walls
Not trying to be an ass dude, but you sure didn't give me much to go off of. And I'm tired. Also, that's nowhere near enough port. I'd be shooting for 45-60 square inches.
Edited by Autruche
My Saab 9000 build
Im trying to make my box look like the first one, so how many common port walls would I type in? And if i cut the peices with the cutouts the calculator gave me wouldnt they not fit together right? If I dont have enough port area what does that mean, my sub is not getting enough air? Im trying to squeeze this box in my small trunk hah. Thanks for the feedback though i didnt think anyone was going to get a sketch that fast let alone 3
You'd need to put in 3 for common port walls. As the top, the side, and the bottom of the box are being used as 3 of the walls. Giving your sub more port generally opens it up, and it will get louder and sound much cleaner. What sub is going in? If it's one sub the net volume you have seems a bit odd.
Are those your max dimensions and desired tuning? I could try to whip something up for you if you want.
My Saab 9000 build
