nice to see another gto here on the forums :drink40:
Yep I love mine. I thought I was the only one on here haha.
I also have an 04 and 15 is the way to go in these cars i put a 15 in mine only downside is i have no more trunk room but who cares the gto is no grocery getter. you should try taking out the stock rear shelf speakers so the bass can pass through there also i took mine out since they sounded to muddy it makes it a little bit louder without them.
I took them out when I deadened the rear shelf and played the system before I put the speakers back in and I agree 100%. When I figure out what I really want I think I will pull them once and for all. I also removed the gray thing under the brake light in between the speakers and that really helped also. It was flapping up and down with the sub playing I think that may have ended almost as much rattle as the deadener...
I loved my 15 in 99.9% sure I'll get another next
2004 Pontiac GTO- bolt ons, bagged, CCW's, SQzzz
Check Out my build log
Follow me on IG: @watsupitsdenny
what kind of sub are you looking to get next?
I just looked at your build I love the box you have your Fi in. What are it's dimensions? it's pretty much exactly what I want in my car for my next box.
lol its the first box i built but its pretty rough. The dimensions are 35W*18H*15D the port is 2.5 inches and i forgot how long but it isnt enough its ported to around 32hz. But this is the max you can fit in the gto. you can probably squeeze one more inch in width but if you do 16 in depth i dont think the trunk will close unless you go with a smaller height. if you go with this dimensions most probably the amp has to go in the spare tire well since you are left with very little space on the sides.
you got my vote :drinks:
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
I really like the dimensions you have on your box. I think that about the size I'll do. The box I have coming for my 12's is an Atrend prefab its like 34X14X17 or something like So I'll see how that fits. I was thinking about using the same amp location I have just a larger and possibly parallel to the ground instead of horizontal.
heres my current amp location:
i think that atrend box you have is the same one i had for my l7 is the port on the side of the box?
No It's in the middle of the 2 subs. It's for 2 12s where yours was for 1. I was moderately happy with the atrend box I had my type R in plus its like $20 more than buying 1 from bestbuy that I'd still have to assemble.
Whoops quick on the send button
