Hang on. Are you doing the door speakers with the same frequencies as the SMD's or are they midbass? If so, then there's gonna be a whole mess of problems.
Midbass
you run the rca's from the HU to the DR amp input. Then run rca's from the DR amp output to the Warhorse input i believe, someonw correct me if im wrong.
That would work perfect if the amp has an output, im not too sure if it does or not.
the 6.5 subs are for midbass, and yes it has outputs on all amps not to sure about the warhorse that things still in the package
