hello, SMD Members
i got a question about the RCA cables
im confused on which rcas i have to connect to my amps, i know this might sound noob but this is the first time im connecting more them 2 amps
i made a schematic of how it looks because describing it will be confusing and boring
thanks for the help
That is one confusing picture! How many speakers are you putting on each door? 2 speakers on each door and 1 sub on each door for the front? Then the 2 subs in the back?
like this
you run the rca's from the HU to the DR amp input. Then run rca's from the DR amp output to the Warhorse input i believe, someonw correct me if im wrong.
1999 Monte Carlo
Sony CDX-GT34w
2 Alpine Type R 12"s in 4 cubes tuned to 35hz
American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms)
Stock alt, Stock batt, Big 3 Upgrade
Boston s55- 5 1/4s (doors)
Boston s95- 6x9s (rear deck)
That would work perfect if the amp has an output, im not too sure if it does or not.
never seen an amp without outputs
1999 Monte Carlo
Sony CDX-GT34w
Hang on. Are you doing the door speakers with the same frequencies as the SMD's or are they midbass? If so, then there's gonna be a whole mess of problems.
POTATO!
