Ren504 Posted June 9, 2011 Report Share Posted June 9, 2011 I'm building a new system. I would like to run 4 of the new SWR-823D's 8" subs by Alpine. 600 RMS-1800 Peak. What I need to know is can I run all four on one PDX-M12 or do I need 2 M12's. Thanks for any info Link to comment Share on other sites More sharing options...
412 CVX Posted June 9, 2011 Report Share Posted June 9, 2011 you can run 4 12's on one amp depending on the ohm configuration of the subs, if that's what your asking. if you're asking if you would need more power to run the subs, then it depends on the power handling of the subs. usually you would need more, but probably not since the subs are 8". Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
AI James Posted June 9, 2011 Report Share Posted June 9, 2011 the type R 8s will not like 600rms and they are rated at like 300-350rms Link to comment Share on other sites More sharing options...
Ren504 Posted June 9, 2011 Author Report Share Posted June 9, 2011 the type R 8s will not like 600rms and they are rated at like 300-350rms From what I'm understanding the new 8's have been underated. I read a thread where they were tested side by side against a 12" type r an pretty much held there ground. 1 12" sealed box an 2 8" sealed box ran of one PDX-M12. The thread an test was done by a Alpine worker. I'm by far no expert I'm just going off the info I find. So I should be good running all 4 8's off that 1 M12? Just trying to get a clear pic of things Bro. Link to comment Share on other sites More sharing options...
AI James Posted June 9, 2011 Report Share Posted June 9, 2011 HAving some type r 8s i warn you to not use them daily on 600rms each unless you wanna smell them fast. 4 on a M12 sounds very safe though. Link to comment Share on other sites More sharing options...
Ren504 Posted June 9, 2011 Author Report Share Posted June 9, 2011 HAving some type r 8s i warn you to not use them daily on 600rms each unless you wanna smell them fast. 4 on a M12 sounds very safe though. Thanks Bro!! Link to comment Share on other sites More sharing options...
AI James Posted June 9, 2011 Report Share Posted June 9, 2011 Yea that test by the Alpine worker on diyma is what I seen as well. They don't like 600 lol Link to comment Share on other sites More sharing options...
Ren504 Posted June 14, 2011 Author Report Share Posted June 14, 2011 Yea that test by the Alpine worker on diyma is what I seen as well. They don't like 600 lol Thanks Homie!! Link to comment Share on other sites More sharing options...
