ok cool so do you think this will be enough to push a Q or BL?
i bought a refurb one from high desert audio on ebay and it pushes my 12" Q like nothin...and its loud as hell too even in a trunk
12" fi q
rf t10001
naw mean
Usually these amps put out around 1400rms at 1ohm. Plenty of power for any q or BL. You'll be quite happy, they're good amps.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
I have one on each of my Q18s @ 2ohms. Each Q is seeing 1000+rms. I had both Qs hooked up to one and it pushed them pretty good @ 1ohm. Both of my T10001bds are refurbs from HDA (High Desert Audio). So I think the less you would see out of a T10001bd is 1000rms @ 2ohm, 1400rms @ 1ohm, but most put out 1500+rms @ 1ohm.
Edited by j_black10
AudioControl
Rockford Fosgate
XSPower
a9cb521a-b3b0-4848-8950-41c45879dd3f_zps
i had the same amp on a 18" bl loaded. it pushed fine. my new powerbass xa-3000d pushes way better. + 2 db's th_Stereo136.jpg
Edited by gotFI?
