ok so i have 2 rockford fosgate 1500bd from 2003 i want to get the 2 12" aa havoc my question is that if i should keep these amps or get something better any help is apriciated thanks
Rockford Fosgate makes quality amps. if they still work you might as well keep them and put them to good use
see thats the problem the havoc is a 2ohm so the only options on wiring them is 1ohm or 4ohm or so i think, my amp at 4ohm does 750rms and they are not stable at 1ohm at 2ohm it does 1500rms so what should i do wire them at 4ohms and not get the full power out of my amps or just replace them with something that is 1ohm stable thanks
I would pick either a Crescendo BC2000 or BC3000D amp or Audioque AQ2200D. The BC2000D might make over 2KW with proper electrical, the AQ2200D will do a little over 2.2KW with good elec. and the BC3000D is the same, doing a little over/under rated w/good electrical. All are 1 ohm stable. So, just like I did, I sold my amp (JL 450/4) and bought a BC2000D and love it.
1991 Accord
Audioque HDC3 15" (Copper)<--Sub
Audioque HDC3 15" (Copper)<--Backup Sub
Crescendo BC2000D<--Amp
Big 3
1/0 Knu<--Wiring
Eonon 3.5" DVD<--Headunit
Infinity Kappa Perfect<--Mids & Highs
2nd Stock 80Amp alt.
1991 Mustang 5.0
Too many mods
(Sold)
1991 240sx SR20 Red Top
Too many mods
(Sold)
2004 GTO
Just starting mods
ok so is that one of thoes amps for both subs or one for each sub? i will be getting a mechman 220amp alt for my electrical havent decided on witch kind of batteries ima get,im still in the in the mind and paper build stage im new at this so are these amps cheaper than the rockford fosgate 2500bdcp amp?
I had my D2 Havoc on a Rockford T1000 and wired it to 1 ohm. The Havoc is 1250 w RMS, it pounded all day very nicely!!!
Pontiac Grand Prix GT
400a Mean Machine alt.
EIGHT DD 12''s on a DDz2
DD vo 8''s,6''s,5.25''s&tweets
Norfolk, VA
http://www.youtube.c...ser/ovnorfolkva
https://www.facebook.com/groups/TheSPLSpot/473815915987218/?notif_t=group_activity#!/chrishova
http://www.stevemead...__fromsearch__1[/color]
ok so im gonna get the 2 crescendo 3kwp monoblock it looks good and has good power, with a mechman 220amp alt how many batteries should i need?
  • Who's Online   1 Member, 0 Anonymous, 1044 Guests (See full list)
