nCOMP1337 Posted June 13, 2011 Report Share Posted June 13, 2011 (edited) I had fun with this, was just curious how large it would be and it is quite big, I've been told T-Lines arent good with high amounts of power, but as I said this was just for fun, 1 SMD woofer cost moe than my entire setup, so no way would this come to fruition at least not by me This box has a lot of port, mainly due to its nearly 16 inches of mounting depth SUB: SMD / AA 15 Dual 2 Fs: 30.1 Qms: 4.99 Qes: 0.29 Qts: 0.27 Sd: 810cm^2 (half of actual port area, lol) Mounting Depth: 15.75 including stud Outer Diameter: 15.625 Cutout Diameter: 14.125 Sub Displacement: .24 cuft Weight: 73 pounds Box: Outer Dimension: 63 wide x 39 deep x 20 tall Inner Volume: 16.65 cuft after displacement (not accounting further bracing) Tuned to 29.7 Hz Port Length: 114 inches Port area: 256 inches (yes tons, not sure how that will affect its functioning within the T-Line) Now I think if this worked, 3 of these next to each other or stacked in a walled type of configuration (floor to ceiling) would just be cool, just cause I like T-Lines, for the money spent and functionality you would probably want, much easier way to go about a setup like this of course, I just wanted to see how it would look Inside View Complete with X ray Complete Since it will be a while before I can afford my sub, and I have my own design for a box done and too much free time due to no job, I just have a bit of fun trying to design boxes, I wish I knew more about 4th, 6th, and BP designs, those would be fun Edited June 13, 2011 by kynto Quote Link to comment Share on other sites More sharing options...
RAM_Designs Posted June 13, 2011 Report Share Posted June 13, 2011 You could do a classical t-line where you start out at 1.5-2x the sd of the sub and taper it down to 1x the sd. I've never seen anyone do 2x the sd all the way through the line. Quote Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011... Link to comment Share on other sites More sharing options...
nCOMP1337 Posted June 13, 2011 Author Report Share Posted June 13, 2011 Yea, I could taper it, didnt think of that I wouldnt mind trying a taper, I dont know how that affects tuning though and how to calculate for that, is it sort of like horn theory, cause I dont know how to calculate that either Quote Link to comment Share on other sites More sharing options...
