I just wanna know where do most of you guys get your aftermarket harnesses from? And what main wire do you normally connect the remote wire to when connectin a amp or multiple amps?
THE GRADUATE 10:18:2007
Metra, AI, or hardwire to the harness, remote wire would be the ignition if you cant find the remote from the factory harness or am/fm tuner pack in the back. If running multiple amps, run from the ignition wire to a relay that is getting power from battery, or a good 12v signal with atleast 10-20amps, and use that as a remote wire hook up
circuit city, best buy, and a few other local audio shops have everything i need.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   1 Member, 0 Anonymous, 1891 Guests (See full list)
