amp ohm question
ok guys i just got done checking my subbs to see if they are blown and they weren't i dont have access to any fancy stuff so i used a 9 volt battery i had. my question to you guys is since my subbs are dual 4 ohm kicker cvr's i have bolth positives wired up and bolth negatives wired together on each sub but separate from one another and then to the amp i have a orion hcca d2400 amp that is one channel but has 2 positive terminals and 2 negative terminals what is the ohm load my amp is seeing
here is a paint pic in case you don't understand
http://i.imgur.com/ntoXy.jpg
reds represent the (+) wire
green and blue represent the (-) wire
so the subbs are wired at 2 ohms separate so dose that mean the amp is seeing 1 ohm or ??
:unsure:
any help would be appreciated thanks SMD forum
Edited by Blazer Boy280
My Build:Blazer Got Bass
wired in parallel @ 2ohm? I think
Edited by blackrosetiger
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
ok so the kickers are getting roughly 600 watts each is that correct and if so you think thats is fine even though they are 500 watts rms
If they ARE wired for 600 rms they'll be fine. You're just pushing them a little harder then they're designed for.
sorry to double post but if say they were wired back works like positives went to negative to the amp what would it sound like
U would notice the deference...u only do that if you invert them.... And yes 100 watts over won't hurt your subs...
If you are ever satisfied, sounds like you gave up... Never Satisfied ~Team Ns~
Why did you think they were blown?
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
2 270a Mechman Alts
  • Who's Online   1 Member, 0 Anonymous, 1822 Guests (See full list)
