Opinions...
littleitaly1990
My cousin (because she is awesome) just gave me this lil mtx thunder 4122 amp....can it power two infinity kappas?
speaker SPECIFICATIONS
General
Power Handling, RMS 90 Watts
Power Handling, Peak 270 Watts
Sensitivity 95dB
Frequency Response 45Hz - 25kHz
Mounting Depth 2-3/16"
Impedance 2 Ohms
amp specs
The crossover on these work-horse, 2-channel amps is 18dB/octave at 85Hz, switchable from low pass/high pass or full-range. Each features a buffered, isolated full-range output. This lets you daisy chain amps to other subwoofer amps or to high frequency amps. If you plan to use the high level inputs from the factory radio, our "Smart Engage" auto-turn-on circuit makes installation a snap - you won't have to remove the factory radio.
Download Owner's Manual in PDF form.
Specifications
Power 12.5 VDC Input
2 Ohm Load 60 w x 2 Low Level
4 Ohm Load 30 w x 2 Hi Level w/ Smart Engage
Bridged 4 Ohm Load 120 w Crossover
Power 14.4 VDC Hi / Low @ 85Hz
2 Ohm Load 80 w x 2 Fixed, Defeatable
4 Ohm Load 50 w x 2 RCA Output
Bridged 4 Ohm Load 200 w Full Range Only
Dimensions
(with ISO Feet)
7.98" x 9.75" x 2.1"
20.3cm x 24.8cm x 5.3cm
All I know about MTX is that they are a cheap brand but still free is better than nothing...
ALSO any opinions on the FI BL??? How loud is it compared to the btl?.... SQ?
A vitrolic, megalomaniacal sadistic psychopath.
NO
lol thanks ros... i didnt think so but right now they are only being powered by an alpine head unit which pushes 50wx4 soi think im gonna bridge them and throw the speakers in the back and buy some perfects which I already have a rf p500 to power
Regardless of what some other people say or think I still believe that underpowering a speaker or sub will damage it.
Scientia est Vox
SMD SUPER BUYER/SELLER
Guest MegaloManiac
roscoe im sending you a pm regaurding this message
  • Who's Online   1 Member, 1 Anonymous, 553 Guests (See full list)
