XS Power
i mean i know its the stock 100 amp alt that comes with my car... I had that running my car for the last 3 years... But i just put a new one on cause the stock one started the voltage drop.... Then this one didnt fix it... And i charged the batts saturday and that day my amp showed 13.8 volts when i started it... about 2 min of driving around and playing music it was 12.0 again... IDK!!! HELP!!
1 Crossfire XS v2 15"
2 Deka group31a's
1 XS Power D3400 (under hood)
1 Addictive Audio 500.1 :D
1 Rockford 3sixty.2
4 Crescendo pwx 6.5s
2 Pyle Pro Super tweets
1 Crescendo 1000c4
Kenwood excelon x494 Head unit
Big Three upgrade
All 0 gauge of course
1 4.56c^ft box @28hz
(New Best official db score= 151.2 @ 36hz)
Need to put a dmm on that alt.
Does your alternator have an external voltage regulator?
internal and the dmm on the alt will show that its charging at 13.8volts so what would doing that prove???
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
could be something else in your system drawing power causing the voltage drop
you have power windows?
Window motors can drop voltage pretty good if there going bad or stuck
Im taking it to my local shop to see what they think... Im also taking the car in for its 45xxx mile checkup so im going to see if someone can figure it out...
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
Do you think it would be a good idea to just replace the run of 0 back the the rear? I'll make it knu this time and do a neg run as well. Or should I just run another one straight off the alternator back to the rear???
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
will this idea hurt the alt??? thats kinda more what im asking here^^^^
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
You said that even with the rear batteries unhooked and the amp hooked directly to the front battery it still reads 12.0-ish? That makes it seem like its the amp. Although its weird how after you charge the batteries it reads fine for a few minutes then drops off..
I like the oldschool one..
Current System: Stock 2011 Tahoe
Loud as F**K
Just kidding
  • Who's Online   0 Members, 0 Anonymous, 614 Guests (See full list)
