they usually use that as a remote wire. built in. kinda nifty huh?
never heard of it im gonna go and try those ideas yall gave me i hope it works thanks guys :)
2007 Pontiac G6 on 20's
Current System-
Jensen VM-9312 in-dash
(1) Kicker 1500.1
(2) DD 1500 Series 12's
Running Knu Koncepts 1/0 wiring
145.6db- Floorboard
162.9db- Port
1983 Toyota Corolla Station Wagon (SPL Vehicle)
(Under Reconstruction)
keep in touch.
sure will i let yall know tommorrow
Current System-
(1) Kicker 1500.1
145.6db- Floorboard
162.9db- Port
ill be at world finals till sunday :D
soooooo <_< anyway i tried what you said and sure enough the problem is fixed COMPLETELY, not only did it solve the engine noise but it took care of the voice speaker problem, AND now the entire system sounds crystal clear its unbelieveable the difference that putting a better ground made. Thanks alot to everybody that helped me yall some smart peeps. :D
Current System-
(1) Kicker 1500.1
145.6db- Floorboard
162.9db- Port
well james (accordman) helped me with that. but what did you go? ground out the head unit or ground the rca's?
i grounded the cd player case to the battery ground then grounded both the right and left rca's to the cd player case as i figured doing it that way fixed both problem now im gonna go out in a little bit and show some people up :D
Current System-
(1) Kicker 1500.1
145.6db- Floorboard
162.9db- Port
