Good Setup oooor What?
iCool247
Would this be a good setup or is there an easier way?
2 6.5" 150W Rockford Fosgate T2652-S Components hooked up to a 2ch T600.
6.5" details:
Sensitivity: 89 dB
RMS Power Range : 100 Watts
Peak Power Handling: 200 Watts
Frequency response: 55-22000 Hz
Amp details:
RMS Output @ 4 ohm: 200W x 2
RMS Output @ 2 ohm: 300W x 2
600 watts RMS x 1 bridged output at 4 ohms (2-ohm stable in bridged mode)
CEA-2006 compliant
Dynamic Thermal Management cooling system
Differential Input circuitry eliminates hum
variable high- and low-pass filters (50-500 Hz, 24 dB/octave)
variable bass/treble boost (0-18 dB at 45 Hz, 0-12 dB at 12k Hz)
Optional remote bass/treble boost
Class AB amplifier design
MOSFET power and output stages
Preamp inputs and outputs
13-11/16"W x 2-3/16"H x 9-5/8"D
4 6"x9" 3way 200W Rockford Fosgate T1693 hooked up to a 4ch T600.
6"x9" details:
Woofer Composition: Carbon Fiber Filled Polypropylene
Top Mount Depth: 3.43 Inches
Sensitivity: 90 dB
RMS Power Range : 30-100 Watts
Impedance: 4 Ohm
Frequency response: 50-22000 Hz
Design: 3 Way
Tweeter Composition: Aluminum
Amp details:
RMS Output @ 4 ohm: 100W x 4
RMS Output @ 2 ohm: 150W x 4
300 watts RMS x 2 bridged output at 4 ohms (2-ohm stable in bridged mode)
CEA-2006 compliant
Variable high- and low-pass filters (20-500 Hz, 24 dB/octave)
Variable bass/treble boost (0-18 dB at 45 Hz, 0-12 dB at 12k Hz)
Class-AB amplifier design
14-15/16"W x 2-1/4"H x 9-5/8"D
2 6x9's will be in the car and the other 2 will be in a box. So will this be a good set up to do? If you need more info about the products just ask. Hopefully I can get some kind of feedback, anything will help ! I'm new to this stuff.
'01 2DR GMC JimmyPioneer DEH-6300UBMB Quart 6.5'sSoundown Audio SA 8 V2'sMTX RT-202 GONEAudiopipe AP-1800.1D GONE
Bass-less :angry2:
I would try to put all 4 6x9's in the rear deck... putting them in a box just seems like wasting space imho.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
if there like this
a box would work, but as you said free air for the oval style ones as there more like subs than speakers maybe mid bass not 100% though
that system sounds good, but would muti channel amp not be better for the Rockford Fosgate T2652-S Components be better like you have for the 6x9's
  • Who's Online   0 Members, 0 Anonymous, 791 Guests (See full list)
