Hello all,
I am thinking about building a new box for my L7 12s. I have the factory kicker box right now but I am thinkin I want somethin more flashy. I would like to build a box with one port like the one below but I do not know how to figure the airspace and how to tune it for two subs instead of one? I dont know if I am explaining this very well but any help would be appreciated. Also what should I tune my port to? 30-35 hz? Thanks.
-Ross
Project Layla
Truck: 99' F-150
Gathering things for my next build.
SoloX18 build:
http://www.stevemead..._1#entry1576460
RE T-line build:
http://www.stevemead...-between-build/
Design it the same way as designing one for a single sub, and just account for twice displacement. Use the Torres box calculator. Some people on here will have actual input though, I've never ran kicker.
:rofl:
:wub: N8.
No homo...unless you want there to be. :orly3::ehh:
I still say you should ditch the back seat man, 4 bolts and 5 mins. easy to put back in if you change your mind!
1998 SS/T Ram Build Log
- Kenwood KVT-514 and KNA-G510 Navigation
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- Second Skin Dampy Pro
- XS D6500
If we knew your dimensions it would help.
Here's one idea, I know you have a truck so I went by what I could fit in my backseat
20h x 50w x 16d
Port: 16.5h x 4.5w x 26l (L port so figure end correction when you build)
That's figuring for 1 extra baffle and bracing. Be around 5.3 net 34hz w/ 15.66 in^2 port per cube.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
Posted (edited)
Thanks man. I made this quick sketchup of I want to do. If you would run some numbers and double check it for me if you wouldnt mind? Its alittle over the top so dont judge me :peepwall:
Edited by DudeWith4x4
-Ross
Project Layla
Truck: 99' F-150
SoloX18 build:
RE T-line build:
Looks fine to me, I'm assuming thats plexy on this side panel? You'll need to accommodate for it on the plans. A friend of mine did something similar but cut out the MDF on the side wall, made the front wall longer did MDF|Plexy|MDF so the internal volume was the same, but had the look he was wanting. So essentially if you where using .75" plexy and MDF cut your front piece 1.5" longer to cover both pieces and you'd never notice it.
-Zach-
2010 Toyota Tundra
7" BDS on 37's
Yeah I accounted for it when I was running the numbers. So this port will act like a port to both subs and wont over exert the sub closer to the port opening will it? did you freind put LEDS inside his box by chance?
-Ross
Project Layla
Truck: 99' F-150
SoloX18 build:
RE T-line build:
Should work fine, and yeah he had LED strips, one at each corner inside.
-Zach-
2010 Toyota Tundra
7" BDS on 37's
  • Who's Online   1 Member, 0 Anonymous, 670 Guests (See full list)
